Thread Tools Display Modes
Old 08-29-2006, 12:29 PM   #1
Caseyjones906
Caseyjones906 is on a distinguished road
Default Dumb Question
I have a newbie question most will think is dumb. I want to use my hand held router to make a groove that another (square) piece of wood to fit into. Here is my problem. The router rounds off the end of the groove and the square will not fit. What am I doing wrong?
Caseyjones906 is offline   Top - Reply with Quote
Old 08-29-2006, 01:54 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Casey
no dumb questions that I know about .
"There are three kinds of people:
The ones that learn by reading, The few who learn by observation, and the rest of them who have to touch the fire to see for themselves if it's really hot."
Give this a try, Take a some stock the same size as the one you are working on and put it on the end of the cut, you can clamp it down or screw it down to some scrap stock in this way the router has a place to track and keep the cut true and it will help with rip out on the end of the cut also.
Just a note**you can take a hand saw and cut off just a bit of the end of the stock that's going into the slot you just made, about 1/2" to 3/4" should do the trick then it will drop in the slot and cover the dado.
You can also use your router to trim off the ends it's quick and easy on the router table, just hold it up ,on it's edge and move it over the router bit, besure to keep it sq. to the fence with a push block and this will also help from ripping out the stock when you move it over the bit and come out of the pass.
You can also just hold it to the fence and move into the router bit but if it's plywood you will get just a bit of rip out this way.
Hope this helps a bit
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 08-29-2006, 02:57 PM   #3
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi Casy: A router has round bits and leaves a round end if the slot does not go the ends of the material you put the slot in. You can do one of two things. round off the material that goes into the slot. Or use a chisel and square up the the ends of the slot to fit the material going into it. Good luck.. Woodnut65
Woodnut65 is offline   Top - Reply with Quote
DC Question angus Lobby 3 03-31-2008 08:29 PM
making a clear subbase- dumb question rprice54 General Routing 4 01-16-2006 05:22 PM
Question About Smoke mblanc General Routing 8 12-17-2005 08:24 AM
craftman router question tsbrewers Table-mounted Routing 7 05-16-2005 06:54 PM
Table Fence Question Bob Table-mounted Routing 7 12-06-2004 04:42 PM
