| | #1 |
| Registered User New Member | I'm a novice woodworker and recently purchased a Hitachi M12V from Amazon. I'm happy with it so far, but am having trouble finding suppliers or information about template guides that will work with this model. It came with 1 guide, and a template guide adapter. The template guides and adapter mount to the base using 2 small screws that came supplied with the router. I'm not sure how (if I can ever find them) guides would secure to the template guide adapter. The supplied template guide is way to large to use with the dovetail jig I'd like to use (it's my buddy's Sears, and best of all, free). Does anyone have any experience with template guides and these routers? Don't hesitate to dumb it down for me, I'm pretty much a newbie. Thanks to all in advance! |
| | #2 |
| Registered User Forum Geek | Hi: I don't own a hitachi router, however most of the companies supplying router adapters make them to accept a Porter Cable guide bushing. PC guides fit into a 1 3/16th hole in the base plate or adapter. The guides are threaded and have a lock ring that fastens them in. If you buy a set of PC style guide bushings, buy the brass ones, PC puts out a steel set but steel don't lock down well enough with hand tightening only. And should a brass guide come loose it won't damage your router bit. Hope this helps.. Woodnut65 |
| | #3 |
| Forum Contributer Supreme Forum King | Hi vwmowery You may want to drop Bob N a P.M. or a e-mail via the forum,just left click on Bob's name. I think he just got the template guides for his Hitachi,(from WoodCraft I think) but he is a great guy and will give you all the info you want and need, just ask him. ![]() Here's a link you may want to read ▼ http://www.routerforums.com/general-...achi-m12v.html Plus be sure to read the item(s) below "Similar Threads" at the bottom of this web page, this a great help tool for this fourm ![]() One more NOTE ***You can buy a new base plate, like the one from MilesCraft, that will fit any router plus the guides made for the MilesCraft tools, BUT I also recommend you buy a 7" or 8" sq.one from Oak-Park the bigger the better in this case is true. ![]() see the like below http://www.routerforums.com/jigs-fix...-turnlock.html Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 08-31-2006 at 11:58 AM. |
| | #4 |
| Registered User Forum King | Go with this and you can use all of the PC templates. http://www.patwarner.com/round_subbase.html |
| | #5 |
| Registered User Forum Fanatic | Be very careful... the Pat Warner sub bases are very addictive ![]() I would have to second that recommendation. I don't know if he makes a base for the M12 but drop him a line to find out for sure. His website also has a lot of great info on routing. Michael |
| | #6 |
| Registered User Forum King | I made one for my DW625 and one for M12v using just the router but if you have a drill press then it's EZ. here's a link on how to make one. http://www.woodcentral.com/articles/...cles_456.shtml |
| | #7 |
| Registered User Forum King | |
| template guides for Bosch Colt | RuggerJoe | Guide Bushings and Templates | 8 | 07-24-2008 12:17 AM |
| 1/4" Collet for Hitachi M12V | RzzB | General Routing | 37 | 05-27-2008 09:11 AM |
| Setting the proper RPM on the Hitachi M12V | jrs4464 | General Routing | 5 | 01-10-2007 10:34 PM |
| Hitachi M12V and Bosch 1619EVS routers | LBrandt | Table-mounted Routing | 3 | 06-03-2006 11:42 AM |
| Hitachi M12V issue | Warren White | General Routing | 4 | 03-23-2005 11:03 PM |
