| This is a discussion on Makita RF1101 Accessories within the General Routing forums, part of the Routers category; Hello all, This is my first post so let me introduce myself. My name is ... |
| | #1 (permalink) | ||
| Registered User ![]() |
Hello all, This is my first post so let me introduce myself. My name is Matt and I live in the suburbs of Chicago. I'm a web developer by trade and just started woodworking as a hobby. In any case, I've become sort of a Makita tool nut as they are rather affordable (in comparison to Festool and other such tools) and they are top of the line as far as I can tell and from what I've used of them so far. That being said, I picked up the RF1101 router kit. I've read that you can use the guide bushings that fit the Porter Cable 690 but have not bought/tried this yet. Searching for other accessories for this router has been sort of tough as I can't find much info on it other than companies selling it or what's on Amazon reviews. My question, thus, is this: Kind of like the guide bushings, what other accessories/jigs that go with other routers can I use with this router? Or, alternately, what plates that fit this router can I buy to make other accessories work with it? Thanks in advance for any insight that can be offered. | ||
Sponsored Advertisement - Register now to remove this advertisement.
** Please be sure to read our Disclaimer at the bottom of the page. **
These advertisements are only displayed to guests, register now for your FREE account on the worlds largest router and woodworking community! |
| | #2 (permalink) | ||
| Official Greeter ![]() |
Welcome to the router forum, Matt Thank you for joining us. If you are like me, most of the "accessories" you end up with will be home made jigs and templates that you make yourself. dado jigs, circle jigs.... What do you have in mind, boxes? cabinets? toys? outdoor furniture?
__________________ James Sydney, Australia. I don't mind if other members disagree with my comments. I don't profess to know everything, and I may learn something new. | ||
| | #4 (permalink) | |||
| Forum Contributor ![]() |
![]() About the only things I can think of for someone just starting out, other than bushings, is an edge guide and possibly a circle jig. Both are easily made and would provide an opportunity to practice with the router. The edge guide is the only one I can think of that is router specific because they usually mount in holes cast in the base. If you want to mount it in a table, the mounting plate is drilled for the specific bolt pattern. Once you have some projects in mind other jigs will pop up. For instance, if you decide to build some cabinets you may want an adjustable dado jig and shelf pin jig, for drawers/boxes, maybe a dovetail jig. The list sorta goes on, and on, and on. Once again, welcome to the forum ![]()
__________________ John Schaben ![]() The problem with experience is I usually get it immediately after I need it. | |||
| | #5 (permalink) | |||
I've become fascinated with routing and router tables and its like all I can think of throughout the day, it's getting really distracting because it's quite cold here in the Chicago area and I can't go out to the garage to practice.In any case, you bring up a good point, the edge guide. I can't seem to find one available online as Amazon says "Currently Unavailable" and I'm not sure buying straight through Makita is cost effective. However, can I not just make a base for it out of hardboard or something along those lines (maybe 1/4"?) with a round part and then square off the other side or even put a cleat on the straight side so it sits over the edge with a thin piece of hardwood (oak?)? I know I'd have to make sure its square and true which may not be the easiest thing I suppose so I don't know if that's a good idea... Any suggestions? | |||
| | #6 (permalink) | |||
. Search the forum for circle guides, view some of Harrysin's uploads, BobJ3s uploads, jw2170s uploads... just to mention a few contributors. There are a myraid of amazing contraptions displayed here, just browse around![]() Incidentally, you mentioned needing to make it square and true,,, to what? Router bit is round We've become conditioned to working with saws where the blade is spinning around a horizontal axis that we tend to carry that thinking over to routers where the cutter is spinning around a vertical axis. It does change some of the rules, just need to keep the direction of rotation in mind.
__________________ John Schaben ![]() The problem with experience is I usually get it immediately after I need it. Last edited by jschaben; 11-02-2011 at 11:29 AM. | |||
| | #7 (permalink) | ||
Thanks jschaben, I'll search for those. Combining the two jigs seems like a great idea, especially, like you said, since my "shop" is my garage and space is limited. | ||
Sponsored Advertisements. Register to disable this advertisement.
| Tags |
| makita, rf1101, router |
| Makita RF1101 Router | timberthane | General Routing | 6 | 10-27-2011 11:57 AM |
| Can i use a makita router with a makita template guide with a porter cable jig? | oshinobi | Jigs and Fixtures | 2 | 06-17-2009 12:24 AM |
