| | #1 |
| Registered User New Member | Any advise on cutting a sinkhole in a post form countertop? What is the best bit? What about using a template, or free-hand? Is the router the best tool to use or should I go with a jig saw? Thanks for replying.
__________________ Gerry |
| | #2 |
| Registered User Forum Geek | Hi,Gerry: If you are going to do alot of counter tops, it would pay to make a template and use a router with a template guide, and a spiral bit. A sink basin usually comes with a paper template, or instructions for making the hole. I would suggest you lay out the paper template, drill holes through the counter top and use a jig saw with a good blade. Don't push it to hard those post forms do chip. Good luck. Woodnut65 |
| | #3 |
| Registered User New Member | I pushed the blade too often and I am not happy with the hole. I mounted and under mount sink so I will probbaly go with a router to finish it tight to the bowl with a guided bit that will guide on the bowl below. Havent done it yet because you only get one chance to do it right. When I do I will post. Good luck |
| | #4 |
| Senior Moderator Supreme Forum King | Professionals use templates for fast accurate cuts. There is no room for error on expensive counter tops, and no saw will give you the finish a router will, with the possible exception of a rotary saw such as a "RotoZip". Keep in mind that a rotary saw is actually a small router with a spiral cutting bit.
| | #5 |
| Forum Contributer Supreme Forum King | Hi Gerry The links below may help ![]() http://hometips.com/articles/kitch_sink.html http://www.doityourself.com/stry/irpsink http://www.hgtv.com/hgtv/rm_kitchen_...373526,00.html Bj ![]()
| Cutting boards for gifts.... | gad5264 | Project Plans and How To | 13 | 10-19-2007 12:13 PM |
| Kitchen counter top | serge | The Finishing Touch | 1 | 09-19-2006 03:41 PM |
| Cutting sinkhole into kitchen counter: new member | Saw Dust | Introductions | 4 | 09-16-2006 05:46 PM |
| Cutting dados on a router table | paulcomi | Table-mounted Routing | 6 | 08-05-2006 11:52 PM |
