Thread Tools Display Modes
Old 09-17-2006, 05:26 PM   #1
mwm500
Dedicated Member
mwm500's Avatar
mwm500 is on a distinguished road
Default question about router plate
I have a craftsman router and there are 3 holes to mount the bottom plate to the base and there are 3 holes that are closer to the bit (smaller circumfrance).
For a bushing? of some sort any one know about that?
mwm500 is offline   Top - Reply with Quote
Old 09-17-2006, 06:44 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi mwm500
Some Craftsman routers come with a steel guides (templet guides(bushing) that are held place with a steel lock ring nut.
But the adapter must be held in place 1st. with 3 screws.
If you don't have a adapter you can get one from Sears or from HarborFreight that comes with a brass templet guides SET.
for 16.oo bucks with brass guides
http://www.harborfreight.com/cpi/cta...emnumber=37402
BESURE to read the manual PDF file on the same web. page to make sure it will fit your Sears Router, they do list one but I don't know your model number.
http://www.harborfreight.com/cpi/cta...m&ItemID=37402
http://www.harborfreight.com/manuals...7999/37402.PDF
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 09-20-2006, 12:49 PM   #3
labric
Sr. Member
labric's Avatar
First Name: Ric
labric is on a distinguished road
Hi MWM
Depending on the age of your router, Sears has always had a special unique guide bushing set, that you attached to the 3 small holes around the router bit center opening.
The steel guide bushing came in a set of 3, if I recall, and are the same guides used with their dovetail/boxjoint jig. See attached pic.
According to the owners manual for a Sears 315.17490 router,the template guide bushings is part #9 25079. See pics
I noticed on eBay two recent auctions for the above set of Sears guide bushings.
http://cgi.ebay.ca/ws/eBayISAPI.dll?...MEWA:IT&ih=007
http://cgi.ebay.ca/Craftsman-Templat...QQcmdZViewItem
Needless to say, the Sears guide bushing are a pain to change as you have to unscrew the 3 screws to change guides and the guides are steel not brass which can cause damage to your bits if not perfectly centered, as I found out. They are also deeper in depth and designed for their dovetail jig or lettering guides and not versatile for use with 1/4" thick pattern templates.
Options, for using guide bushings would be to change bases either to a universal sub base such as Vermont America #23458 Router Guide Bushing Kit w Plate (also steel bushings)(see pic) or go with a Oak Park 7" x 7" sub base that accepts 1 1/2" brass guide bushings. Bushings are available from either Oak Park or Lee Valley depending on your preference.
Oak Park should have a sub base that fits your router as you can see from the following table. See pics
Oak Park sub Base plates
Base Plate Type A Product #BP012 7” plate with 1 1/2” center hole
Craftsman models
917574 315.17381 315.245070 315.27500
917506 315.17400 315.248851 315.27505
917507 315.17460 315.248862 315.174710
315.24886 315.275061 315.174921 315.244750
315.275082 315.17491 315.17470 315.174321
315.275110 315.17500 315.175060 315.175070
315.175040 315.17571 315.17551 315.248870
315.245900
Base Plate Type B Product # BP013V 7” plate with 1 1/2” center hole
Craftsman model 315.248700 (RE600)
Base Plate Type D Product # BP0457 7” plate with 1 1/2” center hole (no mounting kit)
Craftsman model 315.245000, 315.247000, 315.248870, 315.27500 315.27508, 927508, 925483
You will find that a 7" x 7" sub base is much more versatile to use and will give you better control and balance while routing and if you decide upgrade to the Oak Park table system the 1 1/2" bushings will be inter-changeable with the other plates available.
I hope this info helps you find either the correct bushing set or opens up your available options.
Ric
question-about-router-plate-searsbush.jpg  question-about-router-plate-templateguide2.jpg  question-about-router-plate-41_1_b.jpg  question-about-router-plate-02_bp012_base_plate.jpg  question-about-router-plate-02_bp013v_7_inch_base_plate.jpg
Start Safe!!! Finish Safe !!!
labric is offline   Top - Reply with Quote
Old 09-20-2006, 05:11 PM   #4
Hamlin
Supreme Forum King
Hamlin's Avatar
First Name: Ken
Craftsman routers have those holes for their bushings/guides.
Labric listed and has shown pics of your best option for sears routers. I got lucky and my Oak Park plate mounts to both my sears and my makita. So, I use Oak Parks router plate and brass bushings.
Ken
"A VETERAN"
Old 09-20-2006, 06:32 PM   #5
mwm500
Dedicated Member
mwm500's Avatar
Thanks for all the good info.
Walt
Old 09-20-2006, 06:58 PM   #6
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Walt, the most commonly found guide bushings for Craftsman routers are plastic, and not worth considering. Look at the guide bushing identification post to see different types of bushings here: http://www.routerforums.com/9577-post1.html
need advice for inserting rosseau router plate into bench dog promax cast iron table sf_basilix Table-mounted Routing 7 02-21-2008 07:00 PM
Router Plate Insert Question bill kay Table-mounted Routing 11 01-01-2008 12:58 PM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 02:08 PM
Bosch Router Table Plate Pattern Rhino Starting Off 2 11-24-2007 08:35 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
