1/2 inch and 1/4 inch collet? - Router Forums
post #1 of 7 (permalink) Old 01-21-2012, 01:52 PM Thread Starter
JohnsoGreg2012's Avatar
First Name: Greg
Default 1/2 inch and 1/4 inch collet?
I just ordered my first router. The Hitachi KM12VC to be exact. After reading a few reviews here and other places I decided on that one. I'm assuming the 1/2 inch collet is a bit more sturdy and can handle a bit more than the 1/4 inch (I'm sure I'm not saying that exactly right). So my question is what is the advantage of the 1/4 inch collet and why do router manufacturers make them? Is it just to be more flexiable for users who already have 1/4 shank bits?
Perhaps the better question is what are the pros and cons of both size collets?
JohnsoGreg2012 is offline
post #2 of 7 (permalink) Old 01-21-2012, 01:58 PM
Hi Greg.
Bits with a 1/2" shank are stronger & provide less vibration. Larger profiles are also found with the 1/2" shank. You will find smaller profiles have a 1/4" shank. If I have the same profile available in both sizes I will get the 1/2". After awhile you will have bits with both sizes in your collection & each being the perfect size for the job.
If you were to want to make miniature dove tails with a jig, you will need a bit with a 1/4" shank as the 1/2" shank would be to large the fit thru the tails of the joint. The router you are getting will be able to handle any bit you need to use at the time.
I use an 1/8" roundover frequently & have one set up in a trim router with a 1/4" collet at all times. It's light & easy to handle.
Whittier, CA.
Have a nice & safe day!
jlord is offline
post #3 of 7 (permalink) Old 01-21-2012, 02:28 PM
kp91's Avatar
First Name: Doug
1/2 shank bits whenever possible, that way I don't have to swap collets very often.
1 John 1:9
Fredericksburg, VA
My daughter amazes me https://houndsathazelwild.wordpress....houndgold2016/
kp91 is offline
post #4 of 7 (permalink) Old 01-21-2012, 02:39 PM
Hi Greg
The short is you need both you may not know it now but in time you will many start off with a set of 1/4" shanks router bits and the Mfg. know that..but you will move up to 1/2" shank bits in time like most do..
post #5 of 7 (permalink) Old 01-21-2012, 04:10 PM
Hi Gregg - I'm sure you will like that M12VC
As has been pointed out, you will end up with both. IMO, there is no reason to use a 1/2" shank for bits with a cutting diameter of 3/8" or less, shank just gets in the way of being able to see the cut. Conversely, I don't run 1/4" shanks on anything with a cutting diameter greater than 3/4" except for some small roundovers. Anything in between, I have some of both.
John Schaben
jschaben is offline
post #6 of 7 (permalink) Old 01-21-2012, 07:51 PM
Different sizes are for different applications as stated above. When you get your trim router you'll have the 1/4 inch bits for light, detail, or inlay work.
Have fun on your projects!
waho6o9 is offline
post #7 of 7 (permalink) Old 01-22-2012, 12:45 AM Thread Starter
First Name: Greg
Thanks for the replies. I figured it was somewhat of a common question but a good bit of information to have. I also ordered a MLCS router bit set...1/2 inch shanks. Figured that would truly get me started. I plan on building a simple workbench first, then router table, then a few simple home projects, and eventually a new dining room table (at least that is what my wife wants). So I'll try to post pictures along the way.
Human Verification
Craftsman 315.275110 Router Collet 1/2 inch geraldfry6279 General Routing 4 02-17-2015 07:16 PM
1/4 inch collet extension justin Table-mounted Routing 13 07-13-2013 01:27 PM
Collet Expansion ??? 1/4 to 1/2 dave1384 General Routing 19 01-31-2012 11:12 PM
1/2 inch collet for my vintage Rockwell 2601 router? Mr. Pete General Routing 3 01-02-2012 11:04 AM
1/4 inch collet extensions? rwy General Routing 2 05-02-2005 11:07 AM
