| | #1 |
| Registered User New Member | Can someone tell me the correllation between the speed setting numbers and the actual RPMs on the Hitachi M12V & M12V2 routers? I have both a Hitachi M12V & recently purchased a M12V2. Actually I thought I was getting another M12V, but when it arrived I realized I had bought the M12V2. The 2 routers are different in appearance, but both are variable speed 3 !/4 HP, 15 amp. routers. Are they similar in quality and can they both use all the large bits? Should I send the M12V2 back and try to get the M12V? Thanks |
| | #2 |
| Registered User Member | Hi jrs,,,i have the m12 love it,,,,,,, the speed depends on the dia of the bit,the larger the dia the slower the speed. like panel bits should be run t a slow speed, but u can tell by the sound.......and the way it cut,s tom |
| | #3 |
| Forum Contributer Supreme Forum King | Hi Tom and jrs4464 Yes the router has a voice so to speak , it will tell you if you are working it to hard or to easy , just like all equipment , it takes time with your router to find the voice/tone but most will tell you real quick if it's working to hard.It's not a hummm it's a tone of the bit and the router makes when you are making a pass, it's nice to have a speed control to start but not a hard fast rule,you can always set the speed down to start with and then work up, the faster the bit turns the better the cut but this is not the rule when using big bits, like Panel bits,it's the tone and what you fill comfortable/safe with. I have always been timid (lacking in self-assurance, courage, or bravery; easily alarmed; timorous;.) when it comes to routers and the bit that turns at 20,000 RPM so I always set the speed down to where I like it to be and do a good job without cooking the bit or the wood. Just my 2 cents ![]() Bj ![]()
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 11-08-2006 at 10:14 PM. |
| | #4 | |
| Registered User Dedicated Member | Quote:
Dave | |
| | #5 |
| Registered User Dedicated Member | I bought mine from ALL-IN-ONE WOOD TOOLS a while back (it was on sale) but they have them listed at $249.00 Canadian Here's another Canadian dealer, listed at 279.00 though http://www.houseoftools.com/product.htm?pid=15106
__________________ I am Kenadian! |
| | #6 |
| Registered User Forum Fanatic | If your router came without a speed chart, & it has electronic speed control, with a little math you can make your own chart. Most speed charts, relative to the size of bits 1" & larger dia. usually recommend a tip speed in the range of 104 to 107 mph. For example : 2" dia.bit = 18,000 RPM = 107 mph tip speed 3.5" " = 10,000 " = 104 " " " Lee |
| 1/4" Collet for Hitachi M12V | RzzB | General Routing | 37 | 05-27-2008 08:11 AM |
| Hitachi M12V | aztd | Table-mounted Routing | 2 | 07-26-2006 02:07 PM |
| Hitachi M12V and Bosch 1619EVS routers | LBrandt | Table-mounted Routing | 3 | 06-03-2006 10:42 AM |
| Hitachi M12V issue | Warren White | General Routing | 4 | 03-23-2005 10:03 PM |
| Hitachi M12V Router Problem | dcarriere | Tools and Woodworking | 3 | 12-28-2004 06:50 AM |
