Help
Routing edge on plywood
This is a discussion on Routing edge on plywood within the General Routing forums, part of the Routers category; Hi, I have been rip cutting a sheet of 3/4" birch plywood with my circular ...
Old 10-20-2004, 10:03 AM   #1 (permalink)
Dimitri Guest is on a distinguished road
Question Routing edge on plywood
Report Post Report This Post!
Hi,
I have been rip cutting a sheet of 3/4" birch plywood with my circular saw. I need this one edge to be straight and true as much as possible but it isint. It has a few waves in it from the circular saw. How can I use my router to true up this one long edge? What type of router bit to use?
thanks,
Dimitri
Dimitri Guest is offline
Old 10-20-2004, 10:18 AM   #2 (permalink)
NewMontanaWorkshop's Avatar
First Name: Stan
NewMontanaWorkshop is a jewel in the rough
I'm sure there will be other suggestions, but mine is to make either a sawboard or routerboard, which is just a length of 1/4" hardboard that has a strip of material with a known straight edge attached.
Use the circular saw (or a router with the bit you will use to straighten the edge) to trim the excess hardboard after attaching the straight edge piece. The sawboard/routerboard is then clamped to the material and will make straight cuts for you.
http://bt3gallery.fhauto.com/view_ph...le&id=Dsc00003
Above is my routerboard being used to line up a slot to cut to create a 'toilet-
bolt' clamp track, but using it clamped to the edge of your existing cut would allow you to straighten it out.
Below is a sample of a sawboard.
http://bt3gallery.fhauto.com/view_al...e=Sawboardpics
Note: Be sure to always use the same bit in your router once you have trimmed the hardboard for it's use.
NewMontanaWorkshop is offline
Old 10-20-2004, 02:34 PM   #3 (permalink)
Dewy's Avatar
Dewy is on a distinguished road
You can use a straight edge clamped on the board offset by the distance between cutter and router base.
6" widths of melamine coated chipboard are what I use as a straight edge for such jobs.
An 8' length is cheap enough and can later be used for shelving and such.
I use this method when buying full sheets of plywood from suppliers with no cutting service.
I take a couple of home made folding saw horses then cut the ply in the carpark with a cordless circular saw.
If the saw accidently moves a bit I do the same with my router once I get the ply home.
Dewy
support team at Paltalk voice chat program
Dewy is offline
Routing a decorative edge on the inside of a faceframe? Woodworker 52 Portable Routing 2 01-29-2008 01:00 PM
Help with veneer plywood edge profile magicman22 General Routing 12 10-10-2007 03:13 PM
Routing Plywood kmdsouza General Routing 8 03-30-2007 11:32 AM
Routing Plywood Edges beemerbob Table-mounted Routing 1 12-16-2006 04:04 PM
Rabbeting 3/4" plywood edge WoodenShoe Table-mounted Routing 3 06-13-2006 01:15 PM
