Thread Tools Display Modes
Old 10-20-2004, 01:49 PM   #1
Scotty
Jr. Member
Scotty is on a distinguished road
Question Forgot a groove - now what?
Hi. I'm new here. I have a question. I just built a set of nesting tables. I put a groove on the bottom of each piece that goes between each leg. Can't remember the name of that - is it style or rail or skirt?? Anyway, I remembered to router this groove in two of the tables before I put them together but forgot to on one of them. The complication in doing it now is that there is a 3/16" offset from the front edge of the leg and the rail. Can anyone think of an easy way to route that groove in there? Scotty
Scotty is offline   Top - Reply with Quote
Old 10-20-2004, 03:21 PM   #2
Dewy
Forum Fanatic
Dewy's Avatar
Dewy is on a distinguished road
It depends on the shape of the groove and which way the rounter was mounted to cut those grooves.
If you have a cutter with that section on the tip then it would be possible to make a jig out of MDF with a slot for the router bush to follow.
You wont be able to cut this groove the full length as you would hit the legs.
These ends would need to be carefully cut with a chisel to produce the groove shape then sanded by hand to smooth the cut.
Dewy
support team at Paltalk voice chat program
Dewy is offline   Top - Reply with Quote
Old 10-20-2004, 03:35 PM   #3
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi Scotty:
Can the table be disassembled? If you have an offst trimmer router and the table can't
be dissassembled you could put the groove in the apron of the table and finish the
little bit remaining near the legs with hand tools.
Good Luck, Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 10-20-2004, 04:29 PM   #4
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
Can we have a photo of the problem?
Rick and Bob
The Router Guys
Old 10-20-2004, 07:08 PM   #5
Scotty
Jr. Member
Default How do I attach....
Hi,
How do I add a drawing to the reply?
Old 10-20-2004, 10:26 PM   #6
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
Click on the "Go Advanced"
Scroll down to "Manage Attachments" Click and add your drawing.
Rick and Bob
The Router Guys
Old 10-21-2004, 04:05 PM   #7
Scotty
Jr. Member
Default Here is the rough....
Hi Bob and Rick,
I'm still trying to get this drawing to you. Here goes..
Thanks,
Scoty
Old 10-21-2004, 04:30 PM   #8
FordPrefect
Member
FordPrefect is on a distinguished road
I have never used this but it might help
http://www.leevalley.com/wood/page.a...urrency=1&SID=
FordPrefect is offline   Top - Reply with Quote
Old 10-21-2004, 04:46 PM   #9
Scotty
Jr. Member
Thanks Fordprefect
Scotty
Old 10-23-2004, 03:35 PM   #10
BobandRick
The Router Guys
Forum King
BobandRick's Avatar
Originally Posted by Scotty
Hi Bob and Rick,
Thanks,
Scoty
Looks like your going to have do a little hand work.
I would put a 3/16" spacer piece between the legs then set the V-groove up to cut the groove in the rail. Make sure you don't touch your legs on the start or finish position. Last is to cut by hand the bit you will miss on the start and finish points of the V-groove.
Good luck and think and set up safely
Rick and Bob
The Router Guys
Groove in edge of curved piece imrichb Router Bits - Types and Usage 5 07-06-2007 03:03 PM
New to the forum - Advise PLEASE about Tongue and Groove Flooring Darby Introductions 7 03-25-2007 05:07 PM
Spline vs. Tongue & groove wanart General Routing 1 02-28-2006 07:22 AM
Tongue and groove bits archer_456 General Routing 4 02-18-2005 06:51 AM
