Thread Tools Display Modes
Old 10-20-2004, 10:05 PM   #1
DONALD
Sr. Member
DONALD is on a distinguished road
Default Basic Router Bits
Which type of router bits would you recommend for someone just getting started?. There are so many brands available and the prices range from what looks like a reasonable price to bits that cost much more than my PC 690 with both bases. A good bit is a good investment but I hate to have to sell the farm to get bits that work well and are long lasting.
Are router bit sets a good buy or would you recommend individual bits?
Thank you,,,,,,,,,,DON
DONALD is offline   Top - Reply with Quote
Old 10-21-2004, 11:18 PM   #2
Dewy
Forum Fanatic
Dewy's Avatar
Dewy is on a distinguished road
Here in UK boxed starter sets are a lot cheaper than buying each bit separately.
They have most of what you are likely to need when starting up.
My 1st 12 piece set cost me £30 ($54) and recently a German discount store were selling their own cheap routers ($30) as well as 12 piece sets for £5 ($9)
I bought 3 sets so I would always have cutters to get me out of trouble if I had an accident with a good quality bit.
I want a corner beading bit so as a toolmaker I intend grinding one of the cheap straight bits for this job at a fraction of the cost of buying a proper corner beading bit.
All these sets contain a few straight bits, a dovetail bit, rounding over bits, chamfer bits, cove and core box bits and a laminate trimmer.
So far I have 6 bit sets of varying quality as well as a number of individual bits bought seperately when needed.
The only bit I managed to ruin was a 1/4" bit that I thought wasnt cutting right and then found a screw half routed through in the timber I was cutting a pocket in.
That will teach me to check for metal before using a power tool.
Dewy
support team at Paltalk voice chat program
Dewy is offline   Top - Reply with Quote
Old 10-22-2004, 07:24 AM   #3
ejant
Router King
Supreme Forum King
ejant's Avatar
ejant will become famous soon enough
Go to OakParks site and look at Bob's recommended set. It is a great starter set.
http://us.oak-park.com/catalogue.html?list=RBST--
ejant is offline   Top - Reply with Quote
Old 10-22-2004, 09:22 AM   #4
DONALD
Sr. Member
Thank you for the info. I bought a set made by Hickory for around $90. There are 24 bits in the set but I doubt I will be using some of them. I'm thinking of taking them back and buying the few I will need to start off. We're having UK type weather here this morning................wet and drizzling. Thanks again. DON
Old 10-22-2004, 06:53 PM   #5
delroy33
Supreme Forum King
delroy33's Avatar
delroy33 will become famous soon enough
try and stay away from 1/4" shank bits. there are some aplications where you will have no choice but for the most part 1/2" is available.
roy
start square, finish square
delroy33 is offline   Top - Reply with Quote
Old 10-24-2004, 03:47 PM   #6
Spacemanspiff
Sr. Member
Spacemanspiff is on a distinguished road
For the basic bits such as straight flutes and round-overs I just get cheap "use them 10 times and throw them away" ones ... and save my dollars up for the named bits for TG and V bits, drawer locks etc. I find this works well (as it gives me an excuse to go to the shops more often!!)
The speed of light travels faster than the speed of sound, that's why people appear intelligent until they open their mouth ...
Spacemanspiff is offline   Top - Reply with Quote
Old 10-24-2004, 09:25 PM   #7
denisd
Forum Fanatic
denisd's Avatar
denisd is on a distinguished road
You will find out that it's not the router that's expensive. They are inexpensive compared to the price that you will pay for the bits. Buy the best bits that you can affoprd and treat them with tender loving care.
denisd is offline   Top - Reply with Quote
Old 10-25-2004, 06:59 PM   #8
DONALD
Sr. Member
Do you clean your bits and other cutting tools such as Forstner drills after each use. I used 2 Forstner drills last night for the first time and they showed some discoloration I presume from the pitch in the pine plywood. Do you have a good recommendation for rust protectant?
Old 10-25-2004, 07:36 PM   #9
reible
Supreme Forum King
reible's Avatar
I don't clean bits unless they need it. Certainly not after every use.
Now the next issue is with the forstner bits........ You did not say what kind of bits they are or what color the discoloration is. If they are carbon bits (they were the least costly ones you could find) you may have over heated them and then you will see a blue(ish) color. This type of bit does that at relatively low temperatures (I forgot the actual temperature but it like 250 deg. F). In this case the bit could need replacing. HSS bit work to a higher temperature.
If the bits look more brown, sawdusty color then it might be pitch or glue in which case you can clean them. I would not have expected them to have rusted in that short of time.......
Anyway I hope this helps,
Ed
Old 02-13-2006, 09:01 PM   #10
gcarroll
New Member
gcarroll is on a distinguished road
I found that Infinity Cutting Tools package a set based on the Wood Magazine six must-have router bits. There website is at http://www.infinitytools.com. I do not know anything of their quality.
gcarroll is offline   Top - Reply with Quote
Already Problems neuschu Introductions 7 01-22-2008 11:32 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
New Router my way reible General Routing 14 06-10-2006 11:19 PM
