Thread Tools Display Modes
Old 06-10-2008, 05:07 AM   #21
dave142
New Member
dave142 is on a distinguished road
I know this topic is old now, but can someone explain this thread to me (a novice)
Does any one know of any after market Base replacment for the Older Makita 3 1/4 Hp router Model 3612BR that would allow me to use larger 3.5" raised panel bits?
I have the same router. What is the problem with 3.5" raised bits? they don't fit in the 1/2" collet? Why do you need a different base to use these?
Thanks for helping.
dave142 is offline   Top - Reply with Quote
Old 06-10-2008, 08:45 AM   #22
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
This is the first that I have seen of this post and I am amazed that the definitive advice to buy a vertical cutter was not given, only suggested by one member. The router in question has a 2 3/4" opening and increasing this to accommodate a 3 1/2" cutter would remove the ability to use template guides apart from the time and effort required for an unknown result.
I'm not surprised Dave that the thread puzzled you.
Harry
harrysin is offline   Top - Reply with Quote
Old 06-10-2008, 11:07 AM   #23
dave142
New Member
sorry for a very dumb question but I don't even get what... 2 3/4 opening is. Does that mean the hole for the router bit to go in? Im confused, its inches we are talking?
I don't tend to understand much of the technical stuff on these threads, if I try and make something I usually end up just trying to work out my own way, because I don't get it. lol
Old 06-10-2008, 03:45 PM   #24
cbsjoez1935
Forum Fanatic
cbsjoez1935 is on a distinguished road
Dave,
Don't dispair. The terminology of 2-3/4" opening refers to the hole in your baseplate, where the router bit slips through. Obviously, a 3-1/4" panel bit is not going to fit through a 2-3/4" opening. You are going to have to obtain or make another base plate for your router that has an opening large enough for the router bit to fit through.
Joe Z.
JoeZ If you never made a mistake, you never tried anything
cbsjoez1935 is offline   Top - Reply with Quote
Old 06-10-2008, 04:52 PM   #25
dave142
New Member
oh right.. thanks for explaining that.
I don't know why you couldn't fully plunge the router in, then fit the cutter but I am sure there is a reason or this thread would not exist.
Old 06-11-2008, 12:06 AM   #26
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
Dave, you certainly can do that but as has been suggested by I think bobj3, for safety, a spacer should be fitted to prevent the router from slipping down and opening up the hole in the base should the lock lever fail to grip.
Harry
Makita 3612C mftha General Routing 8 11-23-2008 07:58 PM
MAKITA router model 3620 JMalone General Routing 13 08-12-2008 08:05 AM
Ship Model densships Show N' Tell 19 05-10-2008 06:58 PM
model 315 17351 = model 735-2 mjmpropman General Routing 2 04-28-2008 03:13 AM
craftsman router model #26620 hshumsky Starting Off 2 01-11-2008 02:58 PM
