| | #1 |
| Registered User New Member | Has anyone had a problem with the collet chuck on an MV12 coming loose? Mine has come loose and I cannot figure a way to tighten it. Any help would be appreciated. Don ![]() |
| | #2 |
| Forum Contributer Supreme Forum King | Hi Don You may want to return it to the place you got it, or you can do this but only as a extreme measure. I have done this on equipment and it works but you must be sure you want to. Take a center punch and on one of the threads set the punch in place and strike it,this will deform the thread,do it on the 3rd or 4th thread.(not the 1st or the 2nd) then put it back on and check it,if you still have the same error do it to one more thread on the other side. This is like putting in a lock device (lock nut)(called staking the thread) don't do it to the main stem just the nut. You can always replace the nut quick and easy. Good Luck Bj ![]()
__________________ Bj |
| 1/4" Collet for Hitachi M12V | RzzB | General Routing | 37 | 05-27-2008 08:11 AM |
| Hitachi 3/8" Keyless Chuck 6 Amp Drill | Noddy | Tool Reviews | 5 | 09-17-2007 06:13 PM |
| Hitachi MV12 two wrench system | cbsjoez1935 | Table-mounted Routing | 15 | 04-22-2007 05:51 AM |
| Hitachi M12V Collet chuck loose | idkjs | General Routing | 1 | 11-29-2005 09:36 AM |
| Blowing Hitachi MV12 Speed controllers, HELP | WOODMOULDER | General Routing | 11 | 07-07-2005 01:50 PM |
