Rate This Thread - Wanting an edge guide.
Thread Tools Display Modes
Old 05-14-2008, 06:23 PM   #1
xmonday
xmonday is on a distinguished road
Default Wanting an edge guide
I would like to have an edge-guide to attach to the baseplate of my Ryobi RE 180 PL, but have not been able to find one. Does anyone make one for this router?
Alternatively I would make one, but am puzzled. The two horizontal holes in the baseplate for an edge guide have a diameter of 0.364", measured with an internal caliper. What size rod is supposed to go in them?
I assumed some standard available size plus a little for sliding clearance. Thus for example 0.375" plus a smidgen would make sense.
Likewise the spacing between the two holes is bizarre at 3.332". A dimension of 3.25" or 3.375" would be easier. Nor do these dimensions translate into any rational metric measure.
Any hints or help will be much appreciated by this puzzled edge-guide novice.
xmonday
xmonday is offline   Top - Reply with Quote
Old 05-14-2008, 06:43 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi xmonday
Edge guides are easy to make your own, out of hardwood or plastic.
The plastic or hardwood will take on threaded holes or you can use a tee nut to lock the rods in place or thumb screws will do the job also.
You can also used threaded rod because it's just a bit under size after it's been threaded.
For the rods just buy some long 3/8" bolts, cut off the heads and threads and because most bolts now days have rolled threads on the them the rod is under size and should be just right for the holes in the router base...
Below you will see a quick and easy one you can make.
Workshop Projects
Router Tables plans FREE, plus more
http://www.absolutelyfreeplans.com/W...p_projects.htm
RW Router Tip Archive
www.routerworkshop.com/router_tip_glossary.html
Floating Mortise & Tenon: A strong and Silent Joint
bobj3 is online now   Top - Reply with Quote
Old 05-14-2008, 07:46 PM   #3
jbishop
New Member
jbishop is on a distinguished road
xmonday, Home Depot has an edge guide for Ryobi routers, I think it will fit all of their routers. hopr this helps
John
jbishop is offline   Top - Reply with Quote
Rockler edge guide Falegname General Routing 5 12-02-2007 01:54 PM
Router edge guide mwm500 General Routing 3 11-09-2006 07:30 PM
Router Edge Guide for Hitachi Router cdub101 Introductions 2 07-05-2006 10:45 PM
Rockler Router Edge Guide reds_21 Jigs and Fixtures 1 02-06-2005 10:25 PM
Edge guide for my PC 890 paulcomi Portable Routing 6 10-25-2004 06:21 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106
