Thread Tools Display Modes
Old 10-29-2004, 06:05 PM   #1
-Sam-
Forum King
-Sam-'s Avatar
-Sam- is on a distinguished road
Cool Upspiral Bits
Is it best to use a 1/4" upspiral bit to cut circles than using a straight bit? I figure the slicing action of the upspiral is better for wood than the straight bit which has a chopping action. Just a thought. Later...
Boricua
-Sam- is offline   Top - Reply with Quote
Old 10-29-2004, 07:57 PM   #2
reible
Supreme Forum King
reible's Avatar
If you use the search along the top bar you can find some more interesting reading on spiral bits.
The simple answer is as you say......
Ed
Old 10-31-2004, 10:15 AM   #3
Dewy
Forum Fanatic
Dewy's Avatar
Dewy is on a distinguished road
I use a 1/4" HSS milling machine cutter in my table when routing stopped grooves for bread board edges.
The spiral is the same as the upcut ones and it clears the swarf immediately as it is throwing it down.
I wouldn't use anything else for this application.
When the cutters I have get blunt I will buy some from an engineering supplier.
The ones I use have 3 flutes which are far beter than 2 or 4 flute cutters.
Engineers have known for a great many years that an uneven number of cutting edges work a lot better than any even numbered tool.
Despite this manufactureres still stick with 2, 4, 6, 8 flute etc.
I learned this from my father who worked on aero engines in WW2.
He ground tested the planes before the test pilots took them up.
This was at GAC where the Whittle jet was made and tested.
The chief test pilot, Gerry Sayer, who flew the 1st jet, was my dads drinking buddy during those dark years.
Gerry Sayer, Peggy to his friends, knew the engines were in top condition after my dad had tested them for him.
Dewy
support team at Paltalk voice chat program
Dewy is offline   Top - Reply with Quote
Magnate Router bits kp91 Tool Reviews 2 07-09-2007 04:36 AM
Solid Carbide Bits - More likely to loosen? Chris H Router Bits - Types and Usage 2 01-12-2007 05:46 PM
Need help deciding on bits. ryan.s General Routing 8 03-25-2005 10:35 PM
another sorry question about router bits reds_21 General Routing 7 12-30-2004 05:31 PM
sharpening bits..... reible General Routing 4 09-19-2004 10:34 AM
