| | #1 |
| Registered User Sr. Member | I built a jig for my table saw to hold picture frame at 45 degree vertically, to cut slots for reinforcing splines. (Thought about doing this on router table, but I do not have a slotting bit that gives nearly enough depth.) Anyway, slots are cut, and splines are glued in. But, the splines I cut are oversized, and so I need to trim them. I am worried that trying to rout them with a piloted flush cut bit could splinter them, and remove part of the spline below the edge profile of the slot. (In other words, I want to end up with a perfect triangular spline in that triangular slot, but I'm worried the corner will chip out.) I could trim with a small razor saw, and sand, but seems to be awfully time consuming - -there has to be a better way. Suggestions?
__________________ Lee |
| | #2 |
| Forum Contributer Supreme Forum King | Hi Lee Many, many,many ways to get this type of job done but what works best for me is the bench top belt sander, with a 180/220 belt installed. You can make a small jig to keep it sq. and true to the belt and it will come out looking great. Bj ![]()
__________________ Bj Last edited by bobj3; 02-04-2007 at 03:04 PM. |
| | #3 |
| Registered User Sr. Member | Hi Bob, Thanks for the suggestion. I had considered that, but too lazy today to go out in the bitter cold to buy a fine or extra fine belt! I ended up trimming the splines really close to the frame with my RAS, and then gingerly fed the frame past a piloted bit on the router table. I only fed it from corner of frame to end of spline all the way around, then flipped the frame over, and repeated. There was no tearout, so I guess it was fine. Just a really labor-intensive process to cut slots, make splines, and then glue them in and trim them!
| | #4 |
| Registered User Sr. Member | I use a flush trim hand saw and then hand sand. There are several brands but I have the Veritas aka Lee Valley. I think they go for $20.00 US. It works on dowels, splines, or plugs of any kind. I even used it to trim around a doorway when I was installing a new floor. It is one of my favorite hand tools. And like all hand tools they help keep you warm when you use them. Berry in St Paul |
| | #5 |
| Registered User Sr. Member | I'm building a list of things to order from Lee Valley -- will probably add a flush trim hand saw to it. Thanks,
| picture frame techniques | reds_21 | Tools and Woodworking | 5 | 04-13-2008 09:54 AM |
| Picture frame router bit | ryansdad323 | Table-mounted Routing | 3 | 03-05-2008 08:18 PM |
| Fold-Out picture frame help | edbd1100 | Tools and Woodworking | 17 | 06-30-2006 09:52 PM |
| picture frame | Visteonguy | Show N' Tell | 2 | 11-28-2005 08:24 PM |
| Picture frame molding | reible | General Routing | 4 | 11-14-2004 07:22 PM |
