| | #1 |
| Registered User New Member | Hi, Is plywood ok to work with a router? Or does it chip when worked on? Is MDF better to work with? Or Ply? |
| | #2 | |
| Forum Contributer Supreme Forum King | Hi kmdsouza The normal Plywood can be nasty to rework with the router, brich plywood reworks well, plywood as you know as layers of wood and when you route it you are working with the grain and against the grain and it will chip out, MDF works well but it's just saw dust glued up as a board and is hard on the bits. I like to use MDF, it's true (i.e. 3/4" is 3/4" unlike plywood ) and will come out clean on the cuts but it must be painted most of the time (called sign board sometimes ) or a seal job, because it will pickup moisture like a sponge and should Not be used for outdoor projects. Just my 2 cents. Bj ![]() Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 03-27-2007 at 03:20 PM. | |
| | #3 |
| Registered User New Member | does it get worse with hdf? |
| | #4 | |
| Forum Contributer Supreme Forum King | Sorry Not to sure what "hdf" is Bj ![]() Quote:
| | #5 |
| Registered User New Member | high density fiberboard - hdf like medium density fiberboard - mdf |
| | #6 |
| Forum Contributer Supreme Forum King | Hi Now I know what you are talking about, sometimes call hardboard a real router bit killer ![]() Sold in 1/8" to 1/4" thick the norm with or without holes for hanging tools on. About the same for floor laminate stock, a real bit killer also, construct from layers of material bonded together with resin glue the norm. Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 03-28-2007 at 11:48 AM. |
| | #7 |
| Senior Moderator Supreme Forum King | KM, you might like the most recent post in my blog. It is about bits and addresses some of your questions. You can view it by clicking here: http://blogs.routerforums.com/Mike/
| | #8 |
| Banned Supreme Forum King | I've had pretty good luck routing plywood... cabinet grade ply... NOT the borg ply! ... for basically dados & rabbets... nothing fancy... |
| | #9 |
| Retired Moderator Supreme Forum King | You can do dados and rebates fine in most plywoods but for edge details it is fairly problematic. MDF and substrates like that are definitely bit killers like bj says but they will rout ok otherwise. Corey
| Problem Rabbeting Plywood | JDługosz | Portable Routing | 25 | 01-14-2008 01:56 PM |
| Dovetails In Plywood | rmaxa | Router Bits - Types and Usage | 6 | 12-19-2006 11:00 PM |
| Routing Plywood Edges | beemerbob | Table-mounted Routing | 1 | 12-16-2006 05:04 PM |
| Routing Template | Verlin Garrett | Jigs and Fixtures | 5 | 02-06-2006 04:43 PM |
| Routing edge on plywood | Dimitri Guest | General Routing | 2 | 10-20-2004 03:34 PM |
