Thread Tools Display Modes
Old 04-03-2007, 10:47 AM   #1
Birch
Forum Fanatic
Birch is on a distinguished road
Default Sloppy depth settings!!
Say fellas, I fought again this morning with sloppy or slipping depth settings on my PC 890 in the plunge base. I set the depth I need using my little brass 3/16 (for eample) bar. Start my router cut, plunge, and the ^%$%& cut will go way deeper than I've set it! I've zeroed router before setting depth etc. and screwed the lock knob as hard tight as I dare. Whats going on here?
Birch is offline   Top - Reply with Quote
Old 04-03-2007, 11:14 AM   #2
gregW
Forum Fanatic
gregW is on a distinguished road
I haven't had this problem with my PC 890, but I read in another post that you might need to remove the O-ring between the depth rod locking knob and the base to fix the problem.
Greg
gregW is offline   Top - Reply with Quote
Old 04-03-2007, 01:26 PM   #3
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Birch, is the depth stop rod moving during the cut?
Old 04-03-2007, 03:05 PM   #4
Birch
Forum Fanatic
Apparently it is. SOMETHING is allowing the cut to go way deeper than I want it. I will try again as soon as my current wound heals! See msg I just filed. Thanks.
Old 04-06-2007, 08:13 AM   #5
tmiller
Jr. Member
tmiller is on a distinguished road
I'd be looking to make sure the cutter is not climbing into the work. Make a mark on the cutter shank with a Sharpie and try another cut on the same material to make certain the cutter's tight enough. I've had this happen to me before on a Bridgeport, cutting aluminum.
tmiller is offline   Top - Reply with Quote
Freud 2200E -- How do I set it up for a measured depth plunge cut? Ladd General Routing 8 11-12-2007 04:23 PM
Dovetail Depth of Cut Sherwood Portable Routing 5 09-15-2007 11:28 AM
Simple plunge depth settings kp91 Tools and Woodworking 11 07-16-2007 02:16 AM
Craftsman 315.175040 Router Depth Adjustment gloftis Starting Off 3 06-16-2007 02:55 PM
pc 890 series depth adjustment rabuckner General Routing 4 04-10-2005 02:20 PM
