| | #1 |
| Registered User Forum Fanatic | I am toying with buying a biscuit cutting bit set etc. from MCLS or maybe Grizzly. Any comments from the old wise men. I'm convinced the PC #577 is a marvelous device, but if I can do the same thing with a tool I already have (4-routers) why lay out the money. I acknowledge that doing the biscuit jointing etc with a router may take more time. But is is basically any easier? Thanks gents. ![]() |
| | #2 |
| Marine Engineer Forum King | I have a 577 biscuit cutter, and the speed and accuracy of this machine is worth every penny. There are also applications the router cannot perform that a biscuit jointer can, namely 90 degree joints in the center of a board. hope this helps,
| | #3 |
| Forum Contributer Supreme Forum King | Hi Birch pros. and cons. It's easy on the router table but not so with a plunge router or standard fixed base ![]() If you can get the stock to the router table that's the way to go BUT if the project is to big then the PC #577 is the way to go. I have made many jigs to use on the router table because it so quick and easy to do, the table is always setup all I need to do pop in the slot cutter and do the job. it can be the #0 to the #20 . BUT Right tool for the right type of job. ![]() I don't have the new type Plate Joiner 577 from PC but I have and use the old type about 10 years old or so. You may want to take a look at the link below for the slot cutters. I have all 3 ,Grizzly, eBay ones and the MLCS ones and they are the same. Best price=ebay http://cgi.ebay.com/1PC-1-2-SH-Slot-...QQcmdZViewItem ----------- http://www.mlcswoodworking.com/shops...s/bt_slot.html http://www.mlcswoodworking.com/shops...iscuits_anchor Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 04-07-2007 at 11:10 PM. |
| | #4 |
| Senior Moderator Supreme Forum King | One of the newer biscuit cutters will do more, but this really depends on how often you need the added features to figure out the value to you. I will mention that last month I was in Sears and found their Biz-kit system on clearance for $10. Most routers cound be mounted to the adaptor by drilling a couple holes and this is by far the cheapest method.
| | #5 |
| Forum Contributer Supreme Forum King | I've said it before and I'll say it again, there is no substitute for dedicated tools, biscuit jointer's are now so low in price, here in Australia there are a few at less than $A60.00 so in the USA I'm sure that brands like GMC cost peanuts and for hobby use will last a life time. I know that anyone progressing from dowells to biscuits will never return to dowells after all, what is simpler than marking, ruler not required, after plunging, move from side to side to widen the groove making assembly so simple as the two pieces can be slid into alignment. Harry |
| | #6 |
| Retired Moderator Supreme Forum King | I have used both a dedicated and the router table and the Craftsman biscuit system. I rarely use biscuits myself and I find the dedicated joiner much quicker than any other method. Mike, I didn't like the Craftsman Biscuit System... I think it cost about 40.00 back when I got it as a gift. Seemed clunky to use but at 10.00 if you had to do just a few it would be ok and cheap. Had to do a bunch one time and bought a dedicated unit. Haven't used any of them much since then. I do have the Craftsman Mini-Biscuit Joiner. I use that a ton with my box work. It's made by Ryobi like a lot of Craftsman stuff... they discontinued there own which was in blue and yellow but I use the craftsman a lot for putting knobs on boxes, on mitered boxes where I don't want to use any key's or anything like that. It's a neat little tool and if they ever discontinue it I will buy every blade I can get my hands on and a bunch of the splines. Corey
| | #7 |
| Registered User Forum Fanatic | Ahhhh yes....multiple and mixed opinons! Ha! I guess my instinct is to go with the PC 577. No shimming as might be needed using the router in a table etc. - just adjust the #577 and let 'er go. I will mull it over some more but I truly appreciate your guidance fellas. |
| | #8 |
| Forum Contributer Supreme Forum King | Hi Birch JUST a Note *** No shimming needed on the router table the fence will do all the work for you ![]() Just pop in the slot cutter bit and push the stock into the stock. ![]() All you need to do is put some masking tape on the fence so you can mark a center line. Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 04-08-2007 at 05:37 PM. |
| | #9 |
| Registered User Forum Fanatic | Maybe I'm missing something despite having used the router table for cutting biscuit slots in board edges re panel glue up. However I don't think it can be done re cutting biscuit slots in the face of a board & you can do that with a dedicated biscuit cutter. Lee |
| | #10 |
| Banned Supreme Forum King | If you have to cut in aways from the edge, I think you're correct... otherwise, it could couldn't it? |
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 5 | 01-21-2008 09:54 AM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 07:59 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest - VOTING STAGE!! | Mark | Contests Archive | 13 | 11-05-2006 03:23 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest!! | Mark | Contests Archive | 72 | 10-01-2006 01:02 PM |
| Biscuit Joints with a router | rprice54 | General Routing | 7 | 08-28-2006 02:02 PM |
