Rate This Thread - Router v. Biscuit cutter?.
Thread Tools Display Modes
Old 04-07-2007, 08:44 PM   #1
Birch
Sr. Member
Birch is on a distinguished road
Default Router v. Biscuit cutter?
I am toying with buying a biscuit cutting bit set etc. from MCLS or maybe Grizzly. Any comments from the old wise men. I'm convinced the PC #577 is a marvelous device, but if I can do the same thing with a tool I already have (4-routers) why lay out the money. I acknowledge that doing the biscuit jointing etc with a router may take more time. But is is basically any easier? Thanks gents.
Birch is offline   Top - Reply with Quote
Old 04-07-2007, 09:54 PM   #2
kp91
Forum King
kp91's Avatar
I have a 577 biscuit cutter, and the speed and accuracy of this machine is worth every penny. There are also applications the router cannot perform that a biscuit jointer can, namely 90 degree joints in the center of a board.
hope this helps,
1 John 1:9
Old 04-07-2007, 09:59 PM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Birch
pros. and cons.
It's easy on the router table but not so with a plunge router or standard fixed base
If you can get the stock to the router table that's the way to go BUT if the project is to big then the PC #577 is the way to go.
I have made many jigs to use on the router table because it so quick and easy to do, the table is always setup all I need to do pop in the slot cutter and do the job. it can be the #0 to the #20 .
BUT
Right tool for the right type of job.
I don't have the new type Plate Joiner 577 from PC but I have and use the old type about 10 years old or so.
You may want to take a look at the link below for the slot cutters.
I have all 3 ,Grizzly, eBay ones and the MLCS ones and they are the same.
Best price=ebay
http://cgi.ebay.com/1PC-1-2-SH-Slot-...QQcmdZViewItem
http://www.mlcswoodworking.com/shops...s/bt_slot.html
http://www.mlcswoodworking.com/shops...iscuits_anchor
Bj
Bj
Old 04-07-2007, 11:07 PM   #4
Senior Moderator
Supreme Forum King
Mike has disabled reputation
One of the newer biscuit cutters will do more, but this really depends on how often you need the added features to figure out the value to you. I will mention that last month I was in Sears and found their Biz-kit system on clearance for $10. Most routers cound be mounted to the adaptor by drilling a couple holes and this is by far the cheapest method.
Old 04-07-2007, 11:54 PM   #5
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Default Biscuit jointers
I've said it before and I'll say it again, there is no substitute for dedicated tools, biscuit jointer's are now so low in price, here in Australia there are a few at less than $A60.00 so in the USA I'm sure that brands like GMC cost peanuts and for hobby use will last a life time. I know that anyone progressing from dowells to biscuits will never return to dowells after all, what is simpler than marking, ruler not required, after plunging, move from side to side to widen the groove making assembly so simple as the two pieces can be slid into alignment. Harry
router-v-biscuit-cutter-biscuits-1.jpg  router-v-biscuit-cutter-biscuits-2.jpg
harrysin is offline   Top - Reply with Quote
Old 04-08-2007, 12:02 AM   #6
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
I have used both a dedicated and the router table and the Craftsman biscuit system. I rarely use biscuits myself and I find the dedicated joiner much quicker than any other method. Mike, I didn't like the Craftsman Biscuit System... I think it cost about 40.00 back when I got it as a gift. Seemed clunky to use but at 10.00 if you had to do just a few it would be ok and cheap. Had to do a bunch one time and bought a dedicated unit. Haven't used any of them much since then.
I do have the Craftsman Mini-Biscuit Joiner. I use that a ton with my box work. It's made by Ryobi like a lot of Craftsman stuff... they discontinued there own which was in blue and yellow but I use the craftsman a lot for putting knobs on boxes, on mitered boxes where I don't want to use any key's or anything like that. It's a neat little tool and if they ever discontinue it I will buy every blade I can get my hands on and a bunch of the splines.
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 04-08-2007, 01:36 PM   #7
Birch
Sr. Member
Ahhhh yes....multiple and mixed opinons! Ha! I guess my instinct is to go with the PC 577. No shimming as might be needed using the router in a table etc. - just adjust the #577 and let 'er go.
I will mull it over some more but I truly appreciate your guidance fellas.
Old 04-08-2007, 02:04 PM   #8
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Birch
JUST a Note ***
No shimming needed on the router table the fence will do all the work for you
Just pop in the slot cutter bit and push the stock into the stock.
All you need to do is put some masking tape on the fence so you can mark a center line.
Bj
Bj
Old 04-17-2007, 09:31 PM   #9
Lee Brubaker
Forum Fanatic
Lee Brubaker is on a distinguished road
Maybe I'm missing something despite having used the router table for cutting biscuit slots in board edges re panel glue up. However I don't think it can be done re cutting biscuit slots in the face of a board & you can do that with a dedicated biscuit cutter.
Lee
Lee Brubaker is offline   Top - Reply with Quote
Old 04-17-2007, 10:14 PM   #10
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe Lyddon is on a distinguished road
If you have to cut in aways from the edge, I think you're correct... otherwise, it could couldn't it?
Joe Lyddon is offline   Top - Reply with Quote
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 08:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 06:59 AM
Biscuit Joints with a router rprice54 General Routing 7 08-28-2006 01:02 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
