The Network:
 Recommended Stores:
RouterForums.com - Your Online Router and WoodWorking Community
Login
RouterForums.com Search:
    Advanced Search
FAQ
Reload this Page Adapting Makita sub baeplate for porter cable template guide
General Routing Discuss Adapting Makita sub baeplate for porter cable template guide in the Routers forums; I would like to use porter cable template guides on my makita model 3612. Will I have to make my ...
New Reply | Quick Reply
Thread Tools Search this Thread Display Modes
Old 11-19-2004, 09:12 PM   #1
Arnolds
User Info
Trader Rating: (0)
Gallery: View
Arnolds is on a distinguished road
Default Adapting Makita sub baeplate for porter cable template guide
Send Private Message | View Profile
I would like to use porter cable template guides on my makita model 3612. Will I have to make my own baseplate or is one available for purchase? Any suggestions are welcome. Thank You
Arnolds is offline   Top | Reply with Quote |
Sponsors
You currently aren't registered, click here to register.
Old 11-19-2004, 09:32 PM   #2
reible
Supreme Forum King
reible's Avatar
User Info
Trader Rating: (0)
Gallery: View
I have seen a lot of universal sub-bases so my guess is that someone sells just what your looking for.
While you're checking around look at this post as it has references to a "how-to" on making a sub-base and a reference to where to buy "router stuff online". I could go get the post and list then here but you might enjoy the trip getting there.
http://www.routerforums.com/showthread.php?t=460
Ed
reible is offline   Top | Reply with Quote |
Old 11-19-2004, 11:21 PM   #3
template tom
Forum King
User Info
Trader Rating: (0)
Gallery: View
Arnolds
Why add another base when you can purchase Makita template Guides. As a matter of interest what is the largest diameter guide supplied with the porter cable set? To my mind I believe they are not all the same depth of collar therefore requiring thicker templates for certain sizes.
Tom
template tom is offline   Top | Reply with Quote |
Old 11-20-2004, 05:20 PM   #4
reible
Supreme Forum King
reible's Avatar
User Info
Trader Rating: (0)
Gallery: View
Hi again,
Tom has a good point, if you get the template guide set from Porter Cable the barrels are different lengths which makes them useful for Porter Cable jigs and fixtures. If on the other hand you want the "pc" standard meaning basicly a 1 3/16 hole size on the sub-base then you might want to purchase a set of brass ones with the short (.234-ish) barrel. They work well with cut outs you make in 1/4" wood/plastic/masonite.
To answer Tom's question the largest template guide I have from PC is 1 1/4" which makes since since the hole cut out is only 1 3/16". The brass ones often go to only 1".
To make the barrel thing a little clearer check the attachment show in front a brass set and in the back the PC set.
To make things even more interesting there is the size that oak-park and others? sell that has a 1 3/4" opening. Then we have the "Tom" standard sizes which are a lot larger. He makes some good points to having the larger sizes so use the membership page then locate his info and look up his posts, so good reading on templates and guide bushings.
Ed
Search this Thread:
Advanced Search
template guide and 1/2" collet pab Portable Routing 4 08-11-2006 06:59 AM
Porter-Cable template guide no where to be found jnam Portable Routing 5 07-21-2006 07:54 PM
Porter-Cable template guide no where to be found jnam Jigs and Fixtures 3 02-21-2006 07:15 AM
The use of template guides (Guide bushes) template tom Portable Routing 28 12-04-2004 08:18 PM
Template Guide depth ttait General Routing 3 10-03-2004 05:16 PM
Powered by: vBulletin Version 3.0.3
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd. - Copyright 2007 RouterForums.com - Search Engine Optimization by vBSEO 3.0.0
Professional Web Hosting provided by: RosenMill Technologies
