Thread Tools Display Modes
Old 05-24-2007, 11:50 AM   #1
kensb
New Member
kensb is on a distinguished road
Default Router bit is producing a lot of smoke
Help I am trying to cut a help lap joint using a brand new ½” straight two cutter bit I set the cutting depth of first cut to ½” x ½” using the router at full speed, the problem is the router bit is producing a lot of smoke, should this happen when cutting at above settings?
Any help or guidance please.
Ken
kensb is offline   Top - Reply with Quote
Old 05-24-2007, 11:55 AM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Ken
Hi Ken
What type of wood ?
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 05-24-2007, 11:56 AM   #3
kensb
New Member
Pine
Old 05-24-2007, 12:09 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Pine
If it's green, you will see some, the pitch is cooking so to speak.
But take less of a cut that may help....but take a good look at the bit to see if the Pine pitch is building up on the bit.....if so clean it....
Note*** you don't need to run at 24,000 rpm take it down to 12,000 rpm this can help keep the bit run cooler....speed = heat and kills almost all things .....
besure you are moving the stock over the bit the right way, into the bit...
Table top, it's turning couterclockwize so always left to right with the stock.
-- Fence --
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 05-24-2007, 04:06 PM   #5
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi, Ken, you did'nt say if the bit was carbide or not. If it is HSS bit it's DULL. 1/2" depth of cut in one pass is to much to take off even for a carbide bit. I would clean the bit to get rid of any pine pitch, and try the bit at a depth of 1/4" .
Hpope this helps.. Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 05-24-2007, 08:13 PM   #6
Router is still my name
Forum King
Router is still my name's Avatar
Router is still my name is on a distinguished road
Not all router bits are good quality/razor sharp and more carbide.
1-white side = best but cost the most
2= Freud = one of the sharpest I've ever used
3= CMT = very good if you get them on sale
4= MLCS = very good for the price
and many others in the MLCS class and price.
Also if you go way too slow, you get smoke.
router è ancora il mio nome
Router is still my name is offline   Top - Reply with Quote
Old 05-24-2007, 09:13 PM   #7
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Start with our 1/4" rule. Remove no more than 1/4" in a single pass. For the cleanest cut your router should be run at full speed. Inspect the bit for a sharp edge with no nicks and no sticky build up of pitch. If it is a high speed steel bit and has turned blue - black it has been overheated and lost it's cutting value, replace it with a new bit. Moving your router(or wood past the bit if table mounted) too slow will cause burning and smoke. If table mounted move your wood from right to left so the bit pushes the wood against the fence; free hand routing is opposite of this.
Old 05-25-2007, 07:43 AM   #8
del schisler
Forum Geek
del schisler is on a distinguished road
Default feed right to left OR left to right ???
their are two opinion's IT is right to left OR did bodj3 just got it backwards?? he said left to right that would be feeding with rotation's NOT beeing pickie del
del schisler
del schisler is offline   Top - Reply with Quote
Old 05-25-2007, 11:51 AM   #9
Senior Moderator
Supreme Forum King
Del, when table mounted the proper method is from right to left. This way the rotation of the bit pulls the wood towards the fence. Free hand routing is left to right so again the bit pulls the wood towards the fence. You have seen this on the Router Workshop.
Old 05-26-2007, 07:38 AM   #10
del schisler
Forum Geek
understand That is the way i have been doing it for yrs Only the right way is the way del
del schisler
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
New Router my way reible General Routing 14 06-10-2006 11:19 PM
