| | #11 | |
| The Router Guys Forum King | Quote:
__________________ Rick and Bob The Router Guys Click here to send a greeting card to friend or relative. | |
| | #12 |
| Registered User Forum King | Hi all They say a pic is worth a thousand words. I have included a number of drawing to get things started. 14.s Cutter This is the cutter to insert the internal face moulding of the frame. The template guide is 40mm. (Sorry for the metric but I only work with metric dimensions) This combination will determine the size of the cut-out in the template 15. s 10 s Jig to hold the material secure 400 x 300 x 12mm. material held with the aid of 'Shelf Supports' Jig is held in Jig Holder 400 x 300 x 40mm internal dimensions. 12 s Once the material is secure in the Jig Holder the template is added. 16 s and 17 s are the additional tools required 30mm Guide and 10mm straight cutter and 16mm guide and 10mm cutter. Stages of procedure 5.s rout internal moulding 4.s Set up showing direction of cut 8a s Routing rebate for pic and glass 9s rebate for backing material (if required) 18s Edge treatment this of course will require a rouding over cutter wiyh bearing. All the processes are carried out 100% in the plunge mode. Post you comments and let me know what you think of the technique. |
| | #13 |
| Senior Moderator Supreme Forum King | Thanks for the design Tom. One question; everything I have seen has taught me that external cuts are made clockwise, internal cuts are to be made counter clockwise. You show making the internal cut clockwise. Is there a special reason for this? |
| | #14 |
| Registered User Supreme Forum King | The feed direction looks correct to me. With the router above the work the inside cut would be clockwise, if the router were below (ie table mounted) then the cut would be cc. Ed |
| | #15 |
| The Router Guys Forum King | This looks great Tom. Can you explain what determines the guide sizes to be used?
| | #16 | |
| Registered User Forum King | Quote:
| | #17 |
| Senior Moderator Supreme Forum King | Ok, Now that I am thinking "Above the table" its clear. Almost everything I have done is table mounted. |
| | #18 | |
Tom | |
| | #19 | |
Tom | |
| | #20 | |
Tom | |
| Joke a Day | bobj3 | Lobby | 419 | 11-23-2008 02:19 PM |
| Dunnowood turning, my latest | mit-ch | Woodturning and Lathes | 11 | 11-30-2007 09:51 PM |
| 3000 Point Give away! | Mark | Lobby | 39 | 04-30-2005 09:45 PM |
| Reputation points how to give them | reible | Lobby | 1 | 03-12-2005 06:51 PM |
| Posting images | reible | What is it? | 1 | 01-21-2005 12:11 AM |
