| | #21 | |
| Registered User Forum King | Quote:
First calculate the size of the inlay Prepare a 'female template' which will have to be larger that the cut-out of course. This size is determined by the template guide and cutter used. With a 30mm guide and a 10mm cutter the cut-out will required to be 20mm greater all round this has an off-set of 10mm (Cutter to template guide) To rout an insert to fit exactly into position (Circular or elliptical) use a 16mm template guide and a 4mm cutter as this will produce an off-set of 6mm plus the thickness of the cutter 6mm to produce 10mm required Template Tom Last edited by template tom; 12-26-2004 at 05:28 PM. | |
| | #22 | |
It is now over Two years since I made the post above. It seems there is no real interest in the use of the guides. I would be interested in your reasons why. I do use the router table as not everything can be achieved in the plunge mode, but I see the router used in the table for certain items and I am convinced that it can be better achieved in the plunge Mode. Take the Heart Shaped trinket box that was published in an American woodworking Magazaine (Must try to find the publication again. I loaned my copy to a friend some time ago and it has not been returned) Maybe someone out there saw the article and may still have details of it. Tom | |
| | #23 |
| Forum Contributer Supreme Forum King | Tom "I would be interested in your reasons why" I use the guides in the router table all the time because the table can and will hold the router for me and keep it flat and give me more control of the cut. I do use the plunge router from time to time but the table just works for me on most of the jobs I do, with the plunge router they are light duty jobs, like triming or putting on a edge or when I can't get in on the table then I almost always use a bit with a bearing on the bit.I guess Bob and Rick have brain washed me because I see how they do most things quick and easy with the router table, I have used the plunge router to make the Oak-Park wheels,templates,patterns,inlays,many of the Oak-Park templates hearts ,etc. but it's hard to beat the router table and the way they (Bob and Rick) do it. ![]() But this is just my 2 cents ![]() --------------------------- Hi Tom You may want to read below,they don't show the Heart Shaped trinket box but it maybe listed by some other name. --------------- http://magazine-directory.com/American-Woodworker.htm http://magazine-directory.com/ ---------------------------- American woodworking Magazaine Heart Shaped trinket box Maybe called ▼ jewelry, 93:80–90, 113:64–72 small elegant, 105:52–57 ---------------------------- This index lists stories published from issue 92 - issue 120. Stories are listed by subject, then issue (in bold), and page numbers. For example, the entry, "Beadboard, making, 95:22" appeared in the 95th issue, page 52. # To download a searchable PDF version of the index, click on the the link that follows. Please note that you will need Acrobat Reader to view the file. Windows Users: Right Click and select "Save Target as..." # Macintosh Users: Click and hold or control click the link to download. # Click here to download ▼ http://www.rd.com/americanwoodworker...bDex92-120.pdf Back Issues Some of our past issues are still available for $5.00 each. Call (715) 246-4344 from 8 a.m. to 5 p.m. Central, Monday through Friday, for availability and ordering, or write to: Back Issues American Woodworker Box 83695 Stillwater, MN 55083-0695. Copies of Past Articles Photocopies of previous articles are available for $3.00 each. Call (715) 246-4344 or write to: Copies American Woodworker Box 83695 Stillwater, MN 55083-0695.
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 01-08-2007 at 02:56 AM. |
| | #24 |
| Registered User Forum King | Thanks Bob I'll keep on hunting for it I was only interested in the method that was used as I changed the construction completely Tom |
| | #25 |
| Registered User Dedicated Member | I would like to learn more about templates, how to make them and how to use them. I saw your blog and was pretty impressed. That also might be the way to go just post a link to your blog from the forums. Walt |
| | #26 | |
I certainly have had a go at a number of blogs and you will find some of the projects listed there. SOME Projects in my opinion that can only be completed with the router in the plunge mode with the aid of template guides. Here are a few blogs I have tried out since Rick and Bob introduced me to Blogging http://www.woodshopphotos.com/main.p...542&g2_page=1& http://tomodonnell.bigblog.com.au/ http://routermagic.blogspot.com/ http://templatetom.wordpress.com/200...-new-projects/ http://theonlineauthor.com/templatetom/ Have a look at some of the projects. The people you see in the photographs are from My class of 2005 at the Association for the Blind They were responsible for producing the various projects using the template guide method, Some were partially blind but a few were totally blind. Yes I did produse all the templates and jigs before they began to rout the various projects. As I said To all "TRY THEM FOR YOURSELF" The introduction to the guides has been posted on this forum for all to make a copy. Tom Last edited by template tom; 01-08-2007 at 04:54 PM. | |
| | #27 |
| Senior Moderator Supreme Forum King | Tom, at this time 40 MM guide bushings are still not available in North America. I have contacted several tool stores asking them to request it, and I have contacted Trend, N.A. about including it in their imports. Until we get enough members to request this bushing nobody will listen. In the meanwhile if you will send me the specs I will see about a low quantity production run.
| | #28 | |
I have sent the details of the introduction to the use of template guides to Trend in the UK praising them for at least manufacturing a great variety of Metric and Imperial guides. As most router manufactures have their own guides you will require to purchase a new base. They will only fit onto their Uni Base they supply for most routers which is great. I have asked them to use the information on the promotion of the guides if they wish to do so. I am awaitng feedback from them(Hopefully they will respond) What else can we do other to find a manufacturer willing to produce them. I perquaded Makita Australia to re- introduce the guide which for a while had been ommitted as an accessory for a number of years and I asked them to introduce the 40mm Guide Guess what they did and to this day I've heard nothing since (2Years ago). I honestly think the best bet is Trend as they alredy produce the article anyway. If I can find a way of emailing them I will try to see what they can do. Trend are exporting to America?? Mike keep up the good work Tom Last edited by template tom; 01-08-2007 at 09:15 PM. | |
| Joke a Day | bobj3 | Lobby | 419 | 11-23-2008 02:19 PM |
| Dunnowood turning, my latest | mit-ch | Woodturning and Lathes | 11 | 11-30-2007 09:51 PM |
| 3000 Point Give away! | Mark | Lobby | 39 | 04-30-2005 09:45 PM |
| Reputation points how to give them | reible | Lobby | 1 | 03-12-2005 06:51 PM |
| Posting images | reible | What is it? | 1 | 01-21-2005 12:11 AM |
