Thread Tools Display Modes
Old 06-10-2007, 06:43 PM   #11
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Damn Bob, been looking for that stuff for months! Thanks bud!
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 06-10-2007, 06:54 PM   #12
Bob
Forum Moderator
Supreme Forum King
Bob's Avatar
Bob has a spectacular aura aboutBob has a spectacular aura about
Might be a job for a Dremel, but don't know how you would guide it straight.
Cheers,
Bob
Bob is online now   Top - Reply with Quote
Old 06-10-2007, 09:17 PM   #13
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Bob
That's when the Dremel table comes into play , it can be a pain to cut a straight line with it but once it's mounted in the table it's easy job, I use it all the time to cut thin plastic parts true...or to say straight
It's great when you want to just remove a 1/16" or 1/8" and keep it true.
Plus you get small saw blades that work great also and use small router bits in it also.
see snapshot below , just one more way to spend your money, hahahaha but this is a good one.
http://www.amazon.com/Dremel-231A-Sh...1524722&sr=8-1
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 06-10-2007, 10:35 PM   #14
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Clem, to my mind the simplest way to make the groove is to use a straight cutter of the correct size, probably 1/8" on the router table using a tall fence which is a very useful addition to every-ones workshop but don't attempt it in one pass, two or even three with such a small dia. bit. In the photo the material is 1 3/8" with a 5/32" groove. An 1/8" cutter is much cheaper than a slot cutter. Normally in a correct size groove there is no need for glue or pins.
Harry
harrysin is offline   Top - Reply with Quote
Old 06-10-2007, 10:48 PM   #15
Dr.Zook
Supreme Forum King
Dr.Zook's Avatar
First Name: Dave or "Doc"
Dr.Zook is on a distinguished road
Send a message via Skype™ to Dr.Zook
Welcome to the Router Forums Clem and a belated Happy Birthday to you.
Dave
the "Doctor"
Dr.Zook is offline   Top - Reply with Quote
Old 06-11-2007, 01:06 AM   #16
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Harry
You may want to check out the SET of slot cutters below and it's real hard to break one unlike the standard 1/8" straight router bit...
Plus you can just move the stock flat on the top of the router table, no need to hold in up in the Ver. and you don't need to used a tall fence.
I use them all the time to split boxes in to two parts.. top and bottom, quick and easy and safe.
http://cgi.ebay.com/1PC-1-2-SH-Slot-...QQcmdZViewItem
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 06-11-2007, 06:46 AM   #17
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
There lies the difference between our two countries, the cheapest set containing only four cutters is listed at $AUS79.00. If I could get a set at you're kind of prices I like you Bob wouldn't consider any other way. It's a bit like with Niki in Poland, tools are so expensive that he cleverly improvises using what he has to hand.
Harry
Old 06-11-2007, 07:04 AM   #18
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi, Clem: The moulding you are talking about is known as a "T" moulding in the trade.
You will need a slot cutter as Bob has pointed out. The thickness of the T moulding that gets inserted into th table top will dictate what size bit you need, Slot cutters come it thicknesses from 1/16" to 1/2" . You will have to take a scrap board the same thickness as your top and determine exactly what depth you need to adjust the cutter. If the old table top had radius corners you will probably do the same with the new one. It helps to have a hair dryer and gloves to handle the moulding. You will heat the molding up and it will be much more pliable when making bends but it will be hot to the touch. If I remember right we used a slot cutter of about 1/8th'".
I hope this helps. Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 06-11-2007, 09:18 AM   #19
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Harry
All I can say is he ( Ships to: Worldwide )
That's what's neat about eBay many do.
Note*** if he can't do it, I will do it for you, I will buy them and forward them to you or send you one of the 4 sets I have.
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 06-11-2007, 10:40 AM   #20
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
Bob, I have never dealt with Ebay, are they fixed prices or does one have to bid? I would like to buy a set of slot cutters and also a bag of 1/4" dowels, how do I go about it?
Harry
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
New Router my way reible General Routing 14 06-10-2006 11:19 PM
