Rate This Thread - What Router Bit for Table Edging?.
Thread Tools Display Modes
Old 06-10-2007, 02:02 PM   #1
Clem Wixted
New Member
Clem Wixted is on a distinguished road
Default What Router Bit for Table Edging?
My first post on this forum.
I would like to use the plastic edge trim that came off a floding table that got wet and the flake board is disintergrating.
What bit do I use to cut the thin groove in the new table top edge of the 3/4 plywood so I can tap the edge in? I don't know the real name of the plastic edging but it is 3/4 wide and is slightly curved on the face. The back has a thin grooved barbed protruding about 1/4 inch. This barbed protrusion goes into the groove in the table edge.
Any special things I should know before I do this?
Thanks,
Clem
Clem Wixted is offline   Top - Reply with Quote
Old 06-10-2007, 02:27 PM   #2
Bob
Forum Moderator
Supreme Forum King
Bob's Avatar
Bob has a spectacular aura aboutBob has a spectacular aura about
Hi Clem,
I see you made it to the router forum. I believe I must have mis-read your question yesterday and you must have thought my reply was out in left field somewhere. My meds do that to me sometimes I thought you were asking how to trim the plastic to the table top so my reply sure made no sense
You are going to need some form of a slot cutting bit with a bearing. We have a router glossary here in the forum and I will see if I can find the answer for you and return with a better reply if someone does not beat me to it and hopefully they will.
Welcome to the Router forum and don't be shy.
Cheers,
Bob
Pictures from the shop
http://s107.photobucket.com/albums/m292/bnoles616/
Bob is offline   Top - Reply with Quote
Old 06-10-2007, 02:45 PM   #3
Bob
Forum Moderator
Supreme Forum King
Bob's Avatar
Clem,
I think this is the bit you are looking for
http://www.hartvilletool.com/category/776
Cheers,
Bob
Old 06-10-2007, 02:56 PM   #4
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe Lyddon is on a distinguished road
Cool
Clem,
W e l c o m e . . A b o a r d !!
Is the barb end square or pointed?
How thick is the barb that goes into the slot? (Slot width?)
Joe Lyddon is offline   Top - Reply with Quote
Old 06-10-2007, 03:11 PM   #5
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Good that you have some 3/4 inch to use. It's tough to find that thickness. As Bob says the bearing mounted slot cutter is what you need I expect that the thickness of the lug is 1/8 to 3/16 thick.
P.S. welcome to the router forums.
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 06-10-2007, 05:12 PM   #6
Clem Wixted
New Member
Originally Posted by Joe Lyddon
Clem,
Joe,
The barb is pointed and the body is 1/16" and the barbs are about 3/32" but are a little flattened from being in the slot of the previous table.
It also looks like there was a brad driven through the bottom of the table and through the barb to keep it in place.
Clem
Old 06-10-2007, 05:22 PM   #7
Clem Wixted
New Member
Thanks Bob,
I'll see if there is a local source for one of these, otherwise I'll order one online.
Thanks for the info and I'm sorry I didn't explain myself better in my PM to you :-)
Clem
Old 06-10-2007, 05:29 PM   #8
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Clem
I think you are talking about this type of plastic T-edging molding, the norm is a 1/16 slot (5/64") see link below.
It comes in many types but this is the norm. ▼
http://www.rockler.com/product.cfm?O...Select=Details
Use one of the SMALL battery saws with a 1/16" saw BLADE set to 1/4" to 5/16" deep.
They also make it with little arrows sticking out the back side of the molding but that takes a bigger saw blade to do that type 1/8" the morm.
Thanks,
Clem
Old 06-10-2007, 05:29 PM   #9
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe,
Clem
That's a small slot... it may take a little experimentation... slot cutter... or saw.
good luck...
Old 06-10-2007, 05:37 PM   #10
Clem Wixted
New Member
Bobj3 and Joe,
I think I will try the saw slit on some scrap to see if that will work.
Clem
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 08:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 06:59 AM
New Router my way reible General Routing 14 06-10-2006 10:19 PM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
