Rate This Thread - Carvewright 45 Degree edges.
Thread Tools Display Modes
Old 06-27-2007, 09:07 PM   #1
dadsalmon
Dedicated Member
dadsalmon is on a distinguished road
Default Carvewright 45 Degree edges
Can anyone tell me if the Carvewright can be programmed to produce 45 degree angle edges in 1/2 inch material? Mitered corners for small boxes is the object. Can't get these accurate enough on my cheap table saw.
dadsalmon is offline   Top - Reply with Quote
Old 06-27-2007, 09:42 PM   #2
kp91
Forum King
kp91's Avatar
You could always try doing it with a chamfering bit on the router table, and for a whole lot cheaper
1 John 1:9
Old 06-27-2007, 09:45 PM   #3
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
I assume you want all the carving possibilities of the Carvewright machine as well as the 45 miters. Otherwise there are otherways to do this much cheaper. A good table saw can be bought lot's cheaper and if you have a decent router set up you can do as doug advises, Bob and Rick do it. If the Carvewright can do it, member Bob J will know it!
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 06-27-2007, 10:33 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi dadsalmon
I'm not sure why you would want to do this type of job with the Carvewright machine it's true that the machine will take on any router bit you have, well almost all of them but this type of job can be done on the router table or the table saw on the hand router .
The Carvewright machine can't be "programmed" in the true sense of the word it's done with the Designer software that comes with the machine...
and you would select the router bit that you want to do the job and the machine would ask you to put that bit when it's ready to do the 45 deg. cut..
Old 06-28-2007, 07:24 AM   #5
Charles M
Forum Fanatic
Charles M's Avatar
Charles M is on a distinguished road
I haven't used mine for miters yet but my understanding is that it will make them. You can even do 45° miters directly on the machine without any programming. Interestingly it uses a round nose bit (aka: core box bit) instead of a chamfer bit.
Charles M
Freud America, Inc.
Charles M is offline   Top - Reply with Quote
Old 06-28-2007, 02:04 PM   #6
dadsalmon
Dedicated Member
I was not satisfied with the results on the router table with a chamfer bit. Left edges too ragged. I had hoped that would produce superiour results from my cheap table saw. Have limited room in my shop, so I must forgo the luxury of a larger table saw. I have been interested in the cnc routing capabilities, and would certainly use such a machine for far more than mitred edges. Just wondered if anyone had done that yet.
Old 06-28-2007, 02:35 PM   #7
kp91
Forum King
kp91's Avatar
How did the edge look? If there is no means of holding the stock down, the stock can ride up on a chamfer bit and give an uneven edge. Try using your featherboard to press down on the stock, maybe that will give you a better edge.
1 John 1:9
Old 06-28-2007, 03:32 PM   #8
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi dadsalmon
I have not tried it and I would not and this is why
The stock is on a sanding belt (drive belt) and the belt moves the stock under the router bit so to say it will NOT cut the 45deg. true , it will Not destroy the belt that moves the stock to get the true 45deg.cut ,it needs to go by the end/edge of the stock to do so.
It will leave about a 1/16" of stock that you would need to remove by hand with a real sharp knife.... and I'm sure you don't want to do that..
Old 06-28-2007, 09:29 PM   #9
dadsalmon
Dedicated Member
Bob I wonder if it was mounted on a 1/4" piece underneath and riding on it, if the same would be true. How much does programming really control the action of the cutter, or is it predicated strictly by the edges? How bout if it just referenced one edge? Hmmmm......
Old 06-28-2007, 11:39 PM   #10
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi dadsalmon
That may work but I would not try it on my machine...
The program controls the cutter 100% you can select the bit and tell it how deep to run the bit...but the belts are not cheap and are not easy to reinstall on the machine all for a 45deg cut not me...
Tell you what goto the cravewright site and download the software it's free to try for about 60days... this will help you alot with your questions...
http://www.carvewright.com/
CarveWright Show Demo bobj3 CNC Routing 0 03-06-2008 08:58 PM
CarveWright Patterns bobj3 CNC Routing 6 12-07-2007 08:46 AM
CarveWright Demo bobj3 CNC Routing 6 11-18-2007 09:25 AM
Leigh Jig & Tails on Edges (vs. pins) FlyMaster Jigs and Fixtures 2 10-16-2007 10:10 AM
