Thread Tools Display Modes
Old 07-05-2007, 11:27 PM   #1
arkwood
Member
arkwood is on a distinguished road
Default How would you do this??
Making a playing table using 3/4 ply. Drilled hole to start and cut 9 inch strip off of perimeter of sheet of ply, oval on each end. Covered center section with 1/4" foam and wrapped down around edges. This made center 1/2" too large to fit back into outer strip. Being foam I figured I needed an additional 3/16 off the inner side of the outer piece all around, which would allow for good fit with compression of foam. What would be best way to take off the 3/16 using a router. Arkwood
arkwood is offline   Top - Reply with Quote
Old 07-08-2007, 05:05 PM   #2
Mark
Forum Administrator
Supreme Forum King
Mark's Avatar
Mark is an unknown quantity at this point
Bump.
Mark,
Administrator and Technician of RouterForums.com
Contact RouterForums.com
Refer a friend to RouterForums.com!
Mark is offline   Top - Reply with Quote
Old 07-08-2007, 08:23 PM   #3
Senior Moderator
Supreme Forum King
Mike has disabled reputation
You will need to make a template the correct size and use a flush trim bit or one sized to work with guide bushings.
Old 07-08-2007, 09:03 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi arkwood
I think I would use a rabbit bit, many come with diff. size bearing that will let the cutter hang over the bearing....,once around and then go back with a hand tool to finish the job ( hand drill, mounted with drum sander) to remove the small lip left over from the router pass...
http://www.grizzly.com/products/h5548
http://www.grizzly.com/products/h5549
Bj
bobj3 is online now   Top - Reply with Quote
Your Advertisement Here! - Your Advertisement Here! - Your Advertisement Here! - Your Advertisement Here! - Your Advertisement Here! - Your Advertisement Here!
Copyright ©2000 - 2008, Jelsoft Enterprises Ltd. Copyright 2007 RouterForums.com Search Engine Optimization by vBSEO 3.2.0
