| | #1 |
| Registered User New Member | I am trying to make a stave-shell drumset. I've got a PC690 in a table with a straight bit and a lathe. To make each shell, I need to run a 7.5-degree chamfer down both sides of 24 pieces of wood, cut spline grooves in each edge, connect the 24 pieces of wood into a drumshell-shaped construction, and finally turn the shell round on the lathe. Would I be better... 1) trying to find a 7.5-degree chamfering bit and running the stock through flat against the table or 2) building a 7.5-degree wedge and running the stock against the straight bit? Thanks in advance. |
| | #2 |
| Registered User Supreme Forum King | I personal have never seen a 7.5 degree bit but if you could find one that would be a very accurate way to get the right angle. I should also point out I never looked for one so maybe a lot of people sell them????? I'm not sure about what you mean by a wedge? You can make a slide that holds the wood at the correct angle if that is what you mean. I have also seen what are called multi-sided glue joint bits that allow you to do 16 sides (67 1/2 / 67 1/2 degree) (looks like a birds mouth cut). Check Eagle-america for them, or? Maybe they even have a 24 side version?? I would guess you already know how critical the angle and widths are going to be to get this round.... Sounds like a fun project. I would like to see pictures when your done and even along the way.... Ed |
| 45 Degree Lock Miter bit | mjeisenbaugh | Router Bits - Types and Usage | 6 | 03-28-2008 08:09 AM |
| 45 degree lock mitre | f-lhs87 | Router Bits - Types and Usage | 5 | 03-26-2008 09:44 PM |
| Perfect 22.5 degree miter | Kristin D | Tools and Woodworking | 11 | 02-26-2008 06:59 PM |
| Carvewright 45 Degree edges | dadsalmon | General Routing | 14 | 07-10-2007 10:43 AM |
| 60 degree chamfer bit | mapletree | Router Bits - Types and Usage | 8 | 11-02-2006 06:44 PM |
