Thread Tools Display Modes
Old 07-23-2007, 06:53 AM   #1
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Default Something a bit different
A couple of days ago there was a post which included a link showing a trim router in a base which had a light. This struck me as interesting, on many occasions I've found it difficult to see the cutter despite the 40mm guide. An idea formed in my head based on the fact that I had a small LED torch which was about 3/8" in diameter so my friends, here is the result which appears to fulfil it's purpose. You may notice two switches, the second one is for a "laser" beam which I thought could be useful for centering purposes, that is until it became obvious that the centre varies with the height of the router. The only trauma during the making was when I was about to mount the torch and dropped it on the concrete floor. Expletives eventually subsided and I dismantled it and found that one leg on each switch was badly oxidised and solder had never bonded, re-soldering cured the problem and here is the result, there are a couple of duplicated shots with light on light off, I couldn't switch the flash off so a careful look is necessary. A slight twist is all that's necessary to switch on.
something-bit-different-router-light-1.jpg  something-bit-different-router-light-2.jpg  something-bit-different-router-light-3.jpg  something-bit-different-router-light-4.jpg  something-bit-different-router-light-5.jpg
Harry
harrysin is offline   Top - Reply with Quote
Old 07-23-2007, 09:49 AM   #2
Drugstore Cowboy
Forum Geek
Drugstore Cowboy's Avatar
Drugstore Cowboy is on a distinguished road
I've been playing with the idea of doing something similar for a while now.
So far the idea has stayed in my - wonder what if - file.
Thanks for reassuring me the idea is NOT off the wall.
Now --
It's just a matter of getting around to it.
Drugstore Cowboy is offline   Top - Reply with Quote
Old 07-23-2007, 09:57 AM   #3
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
That is pretty cool Harry. Nice modification. That is one of the things I liked about my old Craftsman router.. it had a built in work light that did a pretty good job. My dewalts could use that! Nice job and thanks for the photos as usual.
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 07-23-2007, 09:59 AM   #4
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
I await with interest shots of dozens of guys and gals out there all making their own light in their own way. As always, those first in end up with the worst system, just think of the US NTSC colour TV, first in the world, worst system in the world!(Sorry guys but it's true)
I was in the process of adding a bit when we had a major power flick which re-booted the computer and locked-up the MODEM and ROUTER (no, not the Makita)
I was going to say that the Poms (I used to be one), were the first in the world to start a public TV system which was on 405 lines and ended up the lowest resolution in the world compared to the US 625 which they are now on. But let us not forget that the French with their SECAM system are still on only 525 lines! Have fun making you're router lights.
Harry
Last edited by harrysin; 07-23-2007 at 10:39 AM. Reason: Added last two paragraphs
Old 07-23-2007, 10:41 AM   #5
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
Corey, I learn something every day, I have never seen a router with a light until the one I mentioned. Is this the week when a certain kitchen gets the finishing touches?
Harry
Old 07-23-2007, 10:56 AM   #6
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Harry
I see you used your head and put the light on the part that moves up and down very nice ...
You may want to take a look at the Sears router below it comes with lights built in the router
http://www.sears.com/sr/javasr/produ...TOOL&ihtoken=1
" Variable speed, heavy-duty, permanently lubricated 100 percent ball bearing motor delivers 12,000-25,000 rpm. Soft start permits the motor rpm to slowly increase to the desired speed setting.
Harry ▼
Three integrated work lights clearly illuminate the work surface. Die-cast aluminum motor housing adds strength while limiting and reducing vibration.
Choose either the standard fixed base or dual-arm plunge base with depth gauge, turret stop and machined arms for smooth up/downward motion which plunges up to 2-3/16 inches. Each base features large, clear, 6-11/16 in. sub-base with square edge on the plunge. Oversized debris shield and vacuum shield provide a clear sightline to the bit. Spindle lock allows for easy bit exchanges. Live tool indicator lights up when power connected. Router includes 1/4 in. and 1/2 in. collets, edge guide, bit wrench, operators manual and storage case. Wt. 9.5 lbs.
http://www.routerforums.com/39447-post21.html
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 07-23-2007, 11:06 AM   #7
challagan
Supreme Forum King
challagan's Avatar
Finishing touches... I wish. No... on tap for this week is get the rest of the base cabinets and remove the rest of the old flooring on the other half of the kitchen. Install the new corian counter top on the one half. Then I have to wait for my brother to come and install a new 20 amp circuit for the dishwasher. Then its travel next week and then i can begin see the end of the light!
Old 07-23-2007, 11:09 AM   #8
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
Bob, and there's me thinking that you had retired, you've just done one of the best selling jobs that I've come across for a long time. I can now understand why you Yanks have so many routers, they're as cheap as chips over there. I think you're sales pitch is going to sell a heap of those routers I hope Sears are going to reward you in a suitable way.
Harry
Old 07-23-2007, 11:22 AM   #9
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Harry
Thanks,, that would be nice of Sears but I don't think so ...
Did you take note of the plunge base with the BIG 3/8" rods and the big opening in the base .......once the standard plastic base plate is removed, looks about the same size as yours...but about 5lbs. less.....
You see where I'm going I'm sure
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 07-23-2007, 11:27 AM   #10
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
I sure do Bj. such routers at such low prices make me drool, so please stop torturing me!!
Harry
