| | #1 |
| Forum Moderator Supreme Forum King | While working on my current box which is pretty much a duplicate of the one I just finished and posted, but some modifications and change of wood, I ran into a problem. I am using maple and walnut this time, with the base being some birdseye maple, I went to cut the faux feet into the wood grain ends and when I pushed the maple into the roman ogee bit, it wanted to push back toward me and I ended up with some bad tear out and destroyed the feet. I used the same exact procedure and bit and height as the previous box which was padauk. Now I know maple is a much harder wood, why is this happening? I figured I already messed the base up so I tried the other end and the same thing happened. A 3rd try produceed the same results. I did not experience this on the long grain ends, only the end grain ends. Do I need to slow the router speed down, speed it up or what? Take lighter cuts? What could be going on? It worked so well on the padauk, but horrible results on the maple. I think the router is running at a pretty high speed, but not sure if that is the problem or not. HELP!
__________________ Cheers, Bob |
| | #2 |
| Forum Contributer Supreme Forum King | Hi Bob I would try " lighter cuts" say 1/16" ea. pass... One more thing you may want to try flip the board over, check the wood grain to see if you are going up hill on it...or down the grain.. Bj ![]()
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 07-31-2007 at 10:41 PM. |
| | #3 |
| Registered User Forum Geek | I Would Definately Try Taking Thinner Cuts, The Thinner The Cut The Easier On The Router, And For The Speed Obviousely You Would Think The Higher The Speed The Easier The Cut But I Have Not Used Many Different Types Of Wood Sorry I Camt Help Much. Jeff |
| Cnc advice needed | mderzio | CNC Routing | 5 | 04-09-2008 08:32 AM |
| need advice for inserting rosseau router plate into bench dog promax cast iron table | sf_basilix | Table-mounted Routing | 7 | 02-21-2008 07:00 PM |
| Advice sought on router options | jcarter137 | Introductions | 2 | 02-02-2008 09:57 PM |
| Seeking advice - safety and feasibility | trex021 | Shop Safety | 5 | 04-09-2007 04:45 PM |
| Some advice before going to see the Dr. | Joe Lyddon | Lobby | 1 | 02-13-2007 09:18 PM |
