Thread Tools Display Modes
Old 12-10-2004, 10:02 PM   #1
alanjoel
alanjoel is on a distinguished road
Default end of board routing
I am building a face frame and need to route a rabbit on the end of 1x3 clear pine.
My tests have all resulted in the wood splitting at the end.
Any help for a first time router user.
Thanks Alan
alanjoel is offline   Top - Reply with Quote
Old 12-10-2004, 11:26 PM   #2
JohnH
Dedicated Member
JohnH's Avatar
JohnH is on a distinguished road
My suggestions would be to use a backer board to push your piece past the bit.I would also be sure that the bit is sharp.Also I would reduce the depth of the cut.Making the cut in 2 or three passes will help reduce the tearout.
Hope this helps...
John
JH
JohnH is offline   Top - Reply with Quote
Old 12-10-2004, 11:47 PM   #3
reible
Supreme Forum King
reible's Avatar
Thanks Alan
Hi Alan,
Could you please tell us a little about your set-up? Are you using a table, hand held, straight bit or rabbiting bit, with the grain or across, are you working with a bearing or fence, miter gauge?????? John has some good points but with a little more detail from you we might have even more "good" ideas......
Ed
Old 12-11-2004, 07:50 AM   #4
PEARCO
Jr. Member
PEARCO's Avatar
PEARCO is on a distinguished road
If only the end of a board is to be dadoed or routed, sometimes it pays to over size the piece untill the routing is completed, then cut piece to proper width.
Of course if you are edge cutting all sides, you cut the ends first, then the sides.
PEARCO is offline   Top - Reply with Quote
Dust Colection for routing Dados KentWW Table-mounted Routing 3 01-10-2007 03:18 PM
Cutting groove in cutting board Ken Brown Jigs and Fixtures 1 10-27-2006 10:14 AM
Cutting Board woody Show N' Tell 3 04-02-2006 04:32 PM
Routing Template Verlin Garrett Jigs and Fixtures 5 02-06-2006 04:43 PM
routing accurately spaced grooves in boards for a house entryway system? paulcomi General Routing 5 10-03-2004 06:24 PM
