Thread Tools Display Modes
Old 08-23-2007, 05:57 PM   #1
delirous26
Dedicated Member
delirous26's Avatar
delirous26 is on a distinguished road
Default Coping sled
hi everyone simple question i was looking into a coping sled for the router table does anyone know of a good deal on one or know of a website that can help you make one yourself.any help would be good.
delirous26 is offline   Top - Reply with Quote
Old 08-23-2007, 08:05 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi delirous26
They are easy to make BUT most of the ones you see plans don't work well
Let me explain why they don't work well,,, in order to do a coping cut you must put the Fence on the same type of stock that the sled is made out of in order to get the ( bits) to work right...
Lets say you make your sled out of 1/4" plastic, you should put the 1/4" plastic under the fence as well,,, this will set the bit height for you in a way...
Once you have the strip of plastic screw to the bottom of the fence, now your sled will be at the same height as the bottom of the fence,,,, once your done with the coping bit your set to make the pattern pass on the other parts....all you need to do is put in the pattern bit drop the bit down so it lines up with the coping cut you just did on the other parts of the frame..
Once you have it set lock it down and run your pattern cut and your parts they should come right out on the button...
The sled you can make with some 1/4" MDF or 1/4" plastic and one or two hold down quick clamps you can get from Rockler and many other outlets.
They make many kinds of toggle clamps here a link to some of them.
http://www.rockler.com/product.cfm?p...oggle%20clamps
http://www.rockler.com/product.cfm?O...Select=Details
The one I like is the Rockler #20738 Heavy Duty Lever Clamp, it will let you do just about all from 3/8" to
1 3/8" thick stock....
Note Don't use the screws they come with to hold them in place use flat head screws with nuts,,, to hold them to the 1/4" stock..
If you need any help how to make a siimple sled just ask and I will post a quick drawing of one...
Here's a link to the one that Oak Park sells,,, note the sled and the plastic under the fence...
http://us.oak-park.com/catalogue.html?list=RTS-RPS-
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 08-23-2007, 10:43 PM   #3
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Good info Bj! Thanks!
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 08-23-2007, 10:57 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Thanks Corey
Bob and Rick have it down right, the old pro. knows how to use the router table.....I just watch and learn...
Many ways to get this type of job done but this is one of the easy ways..
But it takes a jig/sled like Oak-Park sells
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 08-24-2007, 06:32 AM   #5
Woodnut65
Forum Geek
Woodnut65 is on a distinguished road
Hi: I would reccomend the sled made by Infinity tools. The bottom plate is solid aluminum, about 5/16ths thick. It won't bed when you clamp something to it.
I think they are charging 99 dolars for it. Woodnut65
Woodnut65 is offline   Top - Reply with Quote
Old 08-24-2007, 08:19 PM   #6
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi delirous26
I should have asked if you wanted to see a snapshot of the Oak-Park jig or to say a copy cat copy of the I made and use..
You will find out I like to take snapshots and post them , alot LOL
SO if you do just ask and it will be done ...
Bj
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 08-25-2007, 11:56 AM   #7
Doyle
Forum Fanatic
Doyle is on a distinguished road
Hi BJ
If you find the time, I would like to see the sled you made. I find there is always something to learn.
Take care
Doyle
Our tools and machines never take prisoners!
Doyle is offline   Top - Reply with Quote
Old 08-25-2007, 12:19 PM   #8
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Doyle
Here's a snapshot or two of the copy cat sled..
I have some BIG panel bits ( 3 5/8" OD )that's way you see the 4 1/4" ID hole in the center and I use it on almost of the router tables...
see below
Bj
Originally Posted by Doyle
Hi BJ
Take care
Doyle
coping-sled-7265.jpg  coping-sled-7266.jpg  coping-sled-7267.jpg  coping-sled-7268.jpg  coping-sled-7269.jpg
coping-sled-7270.jpg  coping-sled-7272.jpg  coping-sled-7273.jpg  coping-sled-7274.jpg  coping-sled-7275.jpg
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 08-25-2007, 12:32 PM   #9
Doyle
Forum Fanatic
Thanks for the reply and the photos of the sled.
After all these years, it was not until I saw your dust collection ring on your router jigs that it occurred to me how to do that.
Thanks BJ.
Take care
Doyle
Old 08-25-2007, 12:39 PM   #10
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Doyle and you'er welcome
Safety Pin Jig
The jig works great for many jobs when you don't need the fence
Plus it can put in place quick with 2ea. small 1/4-20 holes and screw knobs and it works on all router table plates..
Just a note**** the safety pin snapshots got put in by error by me but I think I will just let them be...it's a neat jig that may can make easy and use...by many... I think....
more snapshots of the safety pin & vac. pickup,see URL below
http://www.routerforums.com/52092-post7.html
Bj
Thanks BJ.
Take care
Doyle
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Stiff 1/4” material for a coping sled? Nickbee Jigs and Fixtures 16 11-13-2008 11:42 PM
Shop Made Coping Sled Plans jjciesla Jigs and Fixtures 6 11-19-2007 10:30 AM
Crosscut sled assembly video tileart Jigs and Fixtures 1 09-04-2007 10:10 PM
TS sled for all seasons simplenik Tools and Woodworking 4 06-18-2007 09:23 AM
Crosscut sled - diffefent way to make it simplenik Tools and Woodworking 8 05-29-2007 10:02 AM
