Thread Tools Display Modes
Old 09-09-2007, 08:29 PM   #1
Matison
New Member
Matison is on a distinguished road
Default Bit Slippage.
Hi. I have a DeWalt 610 fixed base router. It has only been used 6 times. Ever since I got it, the bits have slipped while the router was running. This causes the wood to get ruined. I've follwed the instructions on properly inserting the bits. I've inspected, cleaned and then finally replaced the collet, but I always end up with the same result: a ruined project. It is very frustrating. This has never happened to me with my porter cable laminate trimming router. I am wondering if maybe the Dewalt router is vibrating excessively, which is causing the bit to come loose. It is a pretty noisy machine. Any suggestions out there?
Matison is offline   Top - Reply with Quote
Old 09-09-2007, 08:54 PM   #2
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Wow.. not sure what is going on. Take the collet out and blow it out just to make sure. Look down inside the chuck and make sure no burs are present down in there. You put the bit in to the bottom and then pull it up about 1/16 to 1/8 and lock it down? When you tighten the bit are you absolutely sure you are engaging the collet lock button all the way? I love my Dewalt 618 and it is pretty quiet as routers go with a 2 1/4 HP, the quietest one I have and minimal vibration.
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 09-09-2007, 09:21 PM   #3
Matison
New Member
Hi Corey. Thanks for the reply. I do insert the bit completely, and then pull it out 1/16. There is no collet lock button. The 610 has a 2 wrench locking system. I've tried tightening it normally, and I've also tried cinching it down extremely tight. Either way, the bit slips, usually just a little (1/32 or so) in the first minute, and then if I dont shut it off, the bit works its way out almost completely after that. I've cleaned everything several times with air and with alcohol. I've also used different bits - all new ones. There are no burrs that I can see. This router does run extremely fast (one speed only). Maybe a speed contol switch will settle it down some. Either that or I'll throw it out. The wood I have ruined so far has been more expensive than the router. I like to build little boxes with nice wood with various inlays. Most of the stock that I get is pretty pricey. Matt
Old 09-09-2007, 09:26 PM   #4
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe Lyddon is on a distinguished road
W e l c o m e . . A b o a r d !!
Joe Lyddon is offline   Top - Reply with Quote
Old 09-09-2007, 09:28 PM   #5
challagan
Supreme Forum King
challagan's Avatar
Well, that router is the predecessor to the DW 616/618 routers. Obviously there is a problem somewhere with that either the motor or the shaft or both. How old is the router ?
Old 09-10-2007, 01:12 AM   #6
Senior Moderator
Supreme Forum King
Mike has disabled reputation
I am wondering if you have a metric collet and are using SAE shank bits?
Old 09-10-2007, 02:41 AM   #7
roy clarke
New Member
roy clarke is on a distinguished road
That indicates the collet is not closing parallel. If the router and shanks are correct as Mike says, don't mess about, get it replaced.
roy clarke is offline   Top - Reply with Quote
Old 09-10-2007, 08:31 AM   #8
del schisler
Forum Geek
del schisler is on a distinguished road
Default bit slippage
did it ever work ok ?? If not I would take it to a service center And ask what they know about this ? I did a google search and came up with nothing If it is old i would retire it It doesn't have slow start Maybe starting at full speed has something to do with bit slippage Now As many as their are mfd and maybe not as old as your is i am sure this probly has nothing to do with bit slippage ?? tho I have 5 routers and no bit slippage I wouldn't mess around with this problum
del schisler
del schisler is offline   Top - Reply with Quote
Old 09-10-2007, 09:53 AM   #9
Matison
New Member
The router is now approximately 1 year old. I bought it new on Amazon. It has never worked properly. The collet is SAE, and so are the bits.
Matt
Old 09-10-2007, 11:21 AM   #10
Senior Moderator
Supreme Forum King
Matt, It sounds to me like you have a defective collet bushing. One last thing to check before replaceing the bushing though. Get a Micrometer and measure the shanks on a couple of your bits to be sure they are not undersized. The next step is to take your router into a tool store and ask them to let you try one of your bits in a different router, just a spin up test, no sawdust required. Compare the noise levels between the routers. If there is a noticeable difference you may have bad bearings, a bent motor shaft or a damaged collet. They should let you try a new collet bushing to see if the noise and vibration is reduced. If it is you have your solution. If not then there is internal damage to the router which will require repair or replacement. Either way you will have the right answer.
