| | #1 |
| Registered User Supreme Forum King | Some plastics seem to be nice for routing, the cuts are clean and easy to make. Other plastics melt when you try to work with them...... Are there guidelines as to what plastics work well and which don't? On the ones that are usable how about speed settings etc? I guess I'm wishing I could use the router as a mill to form some plastic parts I need. Ed |
| | #2 |
| Forum Administrator Supreme Forum King Join Date: Aug 2004 Location: Winnipeg, Manitoba, Canada First Name: Mark Posts: 3,760 ![]() | I'm not really sure what your asking, but if its about a plastic. I would suggest polyethylene, Oak Park uses this material to make their fences.
__________________ Mark, Administrator and Technician of RouterForums.com RouterWorkshop.net - Get more out of your router! |
| | #3 |
| Registered User Jr. Member | I've routed several kinds - up to 3/4" router bits - full speed. "Lexan" - produced long spider-web strings Acrylic - routs well UHMWPE - difficult but doable. Must push/move hard against the bit - almost to the point where you think you will break the bit! Not surprising - the stuff is designed to reduce friction. * Always on a router table * Always small cuts (1/8") at a time * Always keep the plastic moving to avoid melting |
| | #4 |
| Registered User Supreme Forum King | Hi, I am familiar with polyethylene, that happens to be one that is easy to use but what I am looking for is more of a list of plastics with the property of being "route-able", and maybe a list of plastics that are "not route-able". As an example: One project I have is a part a canon scanner that has to be stiff, 1/8" thick, 4 inches wide by 12 3/4 long with inside cut outs for large film negatives. (oh yes it has to be black or paintable black) One plastic that comes to mind is "lexan" but I don't know it that is workable with a router or if I can get it in a black color. Another is a table saw insert with replaceable zero clearance section......... I have other several "plastic" things that I want to make so the question is meant to be general in nature. Ed |
| | #5 | |
Ed | |
| | #6 |
| Registered User Forum Fanatic | Have you thought of black phenolic? It saws and routes well for me.
__________________ PopPop If it's worth building, It's worth building well. poppop@routerforums.com |
| | #7 |
| Forum Administrator Supreme Forum King Join Date: Aug 2004 Location: Winnipeg, Manitoba, Canada First Name: Mark Posts: 3,760 ![]() | Yes, black phenolic is another good material.
| | #8 | |
Am I thinking of the right stuff if I say it is a laminate, some sort of resin with what looks like linen fabric in it? Ed | |
| | #9 | |
| Registered User New Member | Quote:
John LA | |
| | #10 |
| Registered User New Member | First time working with plastic with a router but I was using 1/2in Optix by Plaskolite which routed really nice for me. Just watch your speed with the different bits. Round Over was nice and easy quarter straight had to go slow. But worked nice. Last edited by RBA; 11-22-2005 at 08:14 PM. Reason: spelling |
| Freehand routing | Visteonguy | General Routing | 50 | 09-08-2008 01:26 AM |
| Dust Colection for routing Dados | KentWW | Table-mounted Routing | 3 | 01-10-2007 03:18 PM |
| Routing Template | Verlin Garrett | Jigs and Fixtures | 5 | 02-06-2006 04:43 PM |
| Routing Tips and Techniques | template tom | Portable Routing | 15 | 01-04-2006 03:52 AM |
| Routing end grain | Pop_pop1 | Table-mounted Routing | 8 | 09-22-2004 01:24 PM |
