Thread Tools Display Modes
Old 10-02-2007, 09:31 PM   #1
S Bolton
Forum Geek
S Bolton is on a distinguished road
Default drill bit size for making router bit storage
Does anyone know what metric drill bit size to use to drill holes for 1/4 and 1/2 inch router bits? I would want them to be just slightly oversized.
13 mm for 1/5 inch?
sb
S Bolton is offline   Top - Reply with Quote
Old 10-02-2007, 10:17 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
HI SB
1/4" is not a big deal but when it comes to the 1/2" size well most don't have the right drill bit size,,, that's to say most have up to 1/2" in the drill bit set..or they jump to the 9/16" size.
This is what I do to get around the error...I find some plastic tubing that is 9/16 to 5/8" OD and has a 1/2" ID size..
Then drill the holes out with the Forstner drill bits to get that flat bottom in the hole.
I also do this for the 1/4" ones also this will help with the humidly that will nail the router bits.....
13 mm for 1/5 inch?
sb
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 10-03-2007, 08:50 AM   #3
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Hi Steve, I've just been busy with a vernier and the best I can do is:
For 1/4"..............6.5mm = 0.255"
.7.00mm=0.27"
For 1/2"..............13mm =0.51"
All three metric drills are "standard" sizes
Harry
harrysin is offline   Top - Reply with Quote
Old 10-03-2007, 10:58 AM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Harry
What size drill bit do you use if you want the 1/2" hole to be just a bit oversize ?
say by .010 to .015
.7.00mm=0.27"
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 10-03-2007, 10:15 PM   #5
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
Bj. a 13mm drill which I measured last night was 0.51" which is 0.01 or 10thou. bigger than 1/2"
Harry
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
Insert Plate size and 11.5" handle spread; how to prevent problems Ladd Table-mounted Routing 34 12-14-2007 02:08 PM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
