Thread Tools Display Modes
Old 10-16-2007, 03:19 PM   #1
Noddy
Forum Fanatic
Noddy's Avatar
Noddy is on a distinguished road
Default Glue and Bits?
Do they mix or should they be kept apart?
Is a glued up pice of material going to be any harder on a bit than just plain (no glue) material going through the bit?
Discuss:
Regards-
Noddy
Noddy is offline   Top - Reply with Quote
Old 10-16-2007, 03:34 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Noddy
Yes, the glue will gull on the bit,,,build up..and it will heat the bit up...
They do make bit cleaner that will remove it and the pitch...it's very hard on bearing as-well ,like lam.trim bits...
Some of the Epoxy glues will nail bits in heart beat...
Discuss:
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 10-16-2007, 06:24 PM   #3
Hamlin
Supreme Forum King
Hamlin's Avatar
First Name: Ken
Yes. Remove the glue. Never fun to a bit get ruined.
Ken
"A VETERAN"
Old 10-16-2007, 06:46 PM   #4
Noddy
Forum Fanatic
Noddy's Avatar
So, what about the case where I take a bunch of strips of 1" X 1" material, glue them up (say for example a multi wood cutting board) and the want to use my router to round over the outside edges, and cut a 'juice groove' around the inside perimeter of the wood?
If this just one of those cases where it can't be avoided, so you route with care, clean your bit after you are done, etc.
Regards-
Noddy
Old 10-16-2007, 06:53 PM   #5
Bob
Forum Moderator
Supreme Forum King
Bob's Avatar
Bob has a spectacular aura aboutBob has a spectacular aura about
Noddy,
Your closing line says it all Go for it.
Cheers,
Bob
Bob is offline   Top - Reply with Quote
Old 10-16-2007, 07:07 PM   #6
kp91
Forum King
kp91's Avatar
First Name: Doug
Glue it up. Rout it.
I've routed tons of MDF (which is basically all glue...) without too much dulling of a router bit. I doubt routing a few passes over a laminated block is going to damage anything.
If you're really worried about ruining a 'good bit', wait until Woodcraft has one of their $5 router bit specials and pick up a round over and a core box bit that you won't be afraid to dull.
1 John 1:9
kp91 is online now   Top - Reply with Quote
Old 10-16-2007, 09:48 PM   #7
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
If your talking about a glued up panel then unless your routing down the glue line then I think the exposure to the bit is very minimal. I think you will be fine.
corey
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 10-16-2007, 10:18 PM   #8
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
We don't avoid stretches of rough road to minimise tyre (tire) wear, the same goes for router cutters and the various materials that we use them on. Don't forget that any cutter that doesn't need to be a critical size can be sharpened by the same people who sharpen saws, so it pays to buy quality cutters that justify the cost of sharpening compared to replacement cost.
Harry
harrysin is offline   Top - Reply with Quote
10 Essential Router Bits Joe Lyddon Router Bits - Types and Usage 35 01-01-2008 02:01 PM
glue joint router bit aurgathor Router Bits - Types and Usage 12 12-05-2007 01:24 PM
Glue bits Glenmore Router Bits - Types and Usage 32 10-23-2007 11:50 PM
Router Bit Size Marking ? joeohlandt Router Bits - Types and Usage 5 04-06-2007 02:09 AM
Rabbetting bit vs straight bit Blind Bruce Router Bits - Types and Usage 3 11-17-2006 09:33 AM
