Thread Tools Display Modes
Old 11-13-2007, 07:47 AM   #1
Deanvandam
New Member
Deanvandam is on a distinguished road
Default Base Plate
Hi everyone,
I just ordered the Freud FT2200E from woodcraft. I want to get an Oak Park Table Top. They have a base plate for the FT2000 & FT2000E. Will This plate fit the FT2200E? For the center hole they have a 1 1/2" hole and a 3 1/8" hole. Which one, do I go with? Any advice will be appreciated. Thanks!
Dean Atkinson (SC)
Deanvandam is offline   Top - Reply with Quote
Old 11-13-2007, 09:00 AM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi,Dean
If you can get both ,,, if not get the 3 1/8" one and you can make your own inserts to fit the 3 1/8" hole...
"Will This plate fit the FT2200E?" b/4 you place your order on the 800 number besure to ask that same question they will know for sure..
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 11-13-2007, 08:20 PM   #3
Deanvandam
New Member
Thanks Bob,
I called Oak Park, They said the FT2000 & FT2000E base plate would not match up to the FT2200E. But, I had them send the base plate with just the center hole. I also purchase a center ring, ($4),to help make sure I mark the drill hole right, and hopefully I will drill them right. You think that will be OK?
Dean Atkinson(SC)
Old 11-13-2007, 10:11 PM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Dean
You beat ,that should work just fine
Why you are in a hold pattern waiting for the base plate take one of the screws out of the router and take it down to the ACE hardware store and pickup 4 or 5 screws the same size, then cut off the heads and then chuck them up it your battery drill and grind the screw to a point (cone point) then when you get the base plate and the brass setup ring screw the new cone point screws into the router then chuck up pin and set the plate in place and then tap the plate with a hammer this will mark the spot you need to drill out the mounting holes,,,,and they will be dead on...
If I recall right the screw size for the Freud is 8mm...
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 11-14-2007, 06:17 AM   #5
Deanvandam
New Member
Bob,
Thats exactly the info I needed. I was wondering how to mark for the drill holes.
You are the best! What seems simple to some, can be diffulcult for others .(ME).
Thanks again!
Dean @ (S.C.)
Old 11-14-2007, 09:17 AM   #6
Fourleftpaws
Forum Fanatic
Fourleftpaws's Avatar
First Name: Larry
Fourleftpaws is on a distinguished road
Send a message via Yahoo to Fourleftpaws
Bob - that is great information - I also was looking for a way to mark a base plate for a different router - that I can not find a base plate for.
Thanks from me too!
FLP
Larry
"Have you hugged your pet today"
Fourleftpaws is offline   Top - Reply with Quote
Old 11-14-2007, 10:03 AM   #7
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
You'er Welcome Dean and FLP
It's one of the install tips I got from Marc Sommerfeld of
( http://www.sommerfeldtools.com/ ) I saw and it blew me away and it stuck in my mind, I now see others are doing it the same way..
It's nice to share with others, it's like pass it on thing and I sure you will
It's so simple and it works so well and it's hard to fail with this trick now you have the trick you can make all the base plates you will need ,(small ones and big ones) with a 1 1/2" drill bit and a 1 3/4" bit you can put in the pocket to hold the Oak Park type brass guides.
http://www.leevalley.com/wood/page.a...000,51208&ap=1
1 3/16 size ▼
http://www.harborfreight.com/cpi/cta...emnumber=95160
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Making your own sub base plate Mike Guide Bushings and Templates 9 08-18-2008 10:43 PM
choosing a base plate ... reikimaster Table-mounted Routing 5 01-13-2006 11:37 PM
Finding the correct base plate Mossy Oak General Routing 2 12-14-2005 07:40 AM
Centering Base Plate -Sam- General Routing 15 01-04-2005 11:15 AM
