Rate This Thread - Router Biscuit Bit Usage Question (jig)???.
Thread Tools Display Modes
Old 11-14-2007, 12:16 PM   #1
Nickbee
Forum Geek
Nickbee's Avatar
Nickbee is on a distinguished road
Default Router Biscuit Bit Usage Question (jig)???
When using a router biscuit bit on a large panel I’m assuming it’s best to do it by hand (not on a table). But when cutting into the panel side you only have the thickness of the material to rest the router base one. So what’s the best way to deal with this? I’m assuming some kind of right angle jig would help? Is there something specific for biscuits?
I’m going to build a smallish carcass for my router table top this weekend and want to see my options. Of course I could always just buy a joiner. But that would dip into my router table goodies fund…
Thanks!
Nickbee is offline   Top - Reply with Quote
Old 11-14-2007, 01:13 PM   #2
gregW
Forum Fanatic
gregW is on a distinguished road
I would use this as a good excuse to buy a pocket hole jig if you don't already have one..they come in real handy and this is an ideal application for it.
Greg
gregW is offline   Top - Reply with Quote
Old 11-14-2007, 03:07 PM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Nickbee
Greg is right on but they are not free most go for about 70 bucks if not more, you can do the job with a slot cutter, to fit the size of biscuit you want to use ,,,all you need is a quick home make jig to fit the bottom of your router and some biscuits , it's bit tricky but not to bad ..the bearing on the bit will do most of the work for you..and the jig..and all you need to put out of your pocket will be about 20.oo bucks...
Thanks!
Bj
Old 11-14-2007, 03:41 PM   #4
Nickbee
Forum Geek
Nickbee's Avatar
Ya bob that was the idea. I like it when a bearing can make an operation brainless
And for the jig,, Can I use a few pieces of MDF joined at a 90 deg angle?
THANKS!
Old 11-14-2007, 03:48 PM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi, Nickbee
Here's a quick one you can make in a heart beat..you don't need the guard but it's nice if you want to set the router down for a just a bit and mark the next slot pocket..........
Slot cutters at the right price ▼
http://cgi.ebay.com/1PC-1-4-SH-Slot-...QQcmdZViewItem
http://cgi.ebay.com/1PC-1-2-SH-Slot-...QQcmdZViewItem
http://cgi.ebay.com/11pc-1-4-Shank-S...QQcmdZViewItem
Over size bearing to fit the slot cutter shank..
D - BEARINGS (for different depth cuts)
http://www.mlcswoodworking.com/shops...ges/katbt7.htm
#12111 1-1/8" OD x 5/16" ID = Cut Depth 3/8"
#12112 1-1/4" OD x 5/16" ID = Cut Depth 5/16"
#12113 1-3/8" OD x 5/16" ID = Cut Depth 1/4"
#12114 1-5/8" OD x 5/16" ID = Cut Depth 1/8"
Screw slots in the base plate, can be put in with two router bits but it sure is nice when you can do it all with just one bit.
http://www.mlcswoodworking.com/order...screw_slot.htm
router-biscuit-bit-usage-question-jig-bisk-jig.jpg  router-biscuit-bit-usage-question-jig-bisk-jig-.jpg
Bj
Old 11-14-2007, 04:12 PM   #6
Nickbee
Forum Geek
Nickbee's Avatar
Ok Bob maybe I’m missing something…
It looks like that jig would be setting the depth of the slot cutter. I think the bearing on a dedicated biscuit bit would de the same thing…
My concern is that when cutting into the “face” of a panel the router base would only have the thickness of the material to sit on (say ¾” MDF in my case this weekend)…
So I guess my game plan was to come up with some type of 90 deg “platform” that could be clamped to the panel for more stability (can you tell I trust my hand / motor skills). Make sense? Is there a better way to skin this cat?
Old 11-14-2007, 05:40 PM   #7
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
H Nick
" Is there a better way to skin this cat?" = Yes ,buy biscuit machine..
Harbor Freight sells a CHEAP one that I don't recommend with a carb.tip 4" blade.
The jig is made so you can control the slot cutter...
The bearing will stop the cutter from going to deep,, and the jig will do the same, some biscuits don't need to be put in deep ,but the jig will let the slot cutter work without taking the router out of your hands..
It's a big bit to be spining on the end on the router... but most of the bit is inside of the jig block..the guard can be moved over the edge of the stock so you get the slot cut true and sq. to the edge..
The depth in the edge is set by the router and it's best to use a standard router NOT a plunge type...you can use the plunge type but it must be locked in place b/4 you start...and must not be moved until your done with all the slots.
Bj
Old 11-15-2007, 06:47 AM   #8
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Nickbee, the thickness of BJ's simple jig is the same as you're material, so part of the router is on the work-piece and the rest is on the bench keeping the router level.
As has been suggested, there really is no substitute for a dedicated jointer and for occasional use a Chinese cheepie will last forever!
Harry
harrysin is offline   Top - Reply with Quote
Old 11-15-2007, 09:07 AM   #9
Nickbee
Forum Geek
Nickbee's Avatar
okay,,,
Here's another question. When using a large bit like a biscuit cutter. If one had the a PC router (2 1/4 HP) with variable speed... Where should the speed be set at? I believe the point of a variable speed router is to slow it down with larger bits (to reduce the bit's MPH),,,,
As you can tell I'm learning lots from lingering on here!!! Thanks guys!
Old 11-15-2007, 10:06 AM   #10
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Nick
Just my 2 cents
I always run the router at it's low speed,,,,the bit will do the job, it's always a bit scarey when the router is screaming in your ear...and can put you on edge...I have used routers for a long time and it still puts me on edge..
That's what's neat about the new type of routers you can turn them down easy.
okay,,,
Bj
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 08:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 06:59 AM
Question about raised panel router bits LBrandt Table-mounted Routing 2 07-08-2006 09:47 AM
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108
