Thread Tools Display Modes
Old 11-19-2007, 03:46 PM   #1
Packy46
Jr. Member
Packy46's Avatar
Packy46 is on a distinguished road
Packy46 is offline   Top - Reply with Quote
Old 11-19-2007, 04:15 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Tim
You can see it on your PC ,,,if you have a quick hookup for the net at
just one more way to see it... for free
THE RWS is now palying..2:00 to 2:30 today
http://www.thewoodworkingchannel.com/
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 11-19-2007, 07:05 PM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
You'er Welcome Tim
At one time they had a SCHEDULE item that you could click on but it's not working most of the time BUT you can sign up for the email and you will get a list of items so you can set your clock to view them...
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 11-19-2007, 08:12 PM   #4
challagan
Supreme Forum King
challagan's Avatar
challagan is on a distinguished road
Bob, are you saying they will email you the schedule?
http://iowacarver.tripod.com/
My Shop Website - Woodshop 51503
http://woodshop51503.tripod.com/
challagan is offline   Top - Reply with Quote
Old 11-19-2007, 10:00 PM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Corey
"Sign up for our email list
Stay connected and receive the most up to date news on upcoming programming and exclusive channel events. "
javascript:Browse('http://viewers.multicastmedia.com/Network_help/HelpFrameset.asp?networkid=3000379');doNada()
http://viewers.multicastmedia.com/Ne...workid=3000379
Why are the videos choppy or freezing?
The quality of the video clip you are watching mainly depends on two factors: (a) the speed of your Internet connection and (b) the bit rate (speed) of the video clip. The faster the bit rate of the video clip, the better the quality. However, the speed of your Internet connection will limit which video clip bit rate that you can watch. For example, if you only have a 56kbs dial up connection to the Internet, the highest video clip bit rate that you will be able to watch will be 56kbs or less (most likely less as the majority of dial-up connections only get speeds of 28kbs or less due to phone line issues). If you try to watch a video clip with a bit rate of 300kbs over a dial up connection, the video will not play. That is why we offer multiple bit rates for each video clip. Each bit rate is optimized for the different types of Internet connections available (Dial-up/DSL/Cable Modem/T1). As you can see, it is very important that you select the proper video clip bit rate for your Internet connection. For the best viewing experience, we recommend a high speed Internet connection such as DSL or Cable Modem.
It is important to note that even if you have a high-speed (DSL/ Cable Modem/ T1), Internet traffic congestion affects your connection speed and/or video performance. You will get slower or faster speeds at different times depending on peak or off-peak use hours. You may also get slower speeds during the morning and afternoon, but faster speeds late at night when fewer people are online. Also, streaming quality decreases when multiple people share the same Internet connection (e.g. at work or on a home network).
View Schedule Error
Server Error in '/' Application.
Runtime Error
Description: An application error occurred on the server. The current custom error settings for this application prevent the details of the application error from being viewed remotely (for security reasons). It could, however, be viewed by browsers running on the local server machine.
Details: To enable the details of this specific error message to be viewable on remote machines, please create a <customErrors> tag within a "web.config" configuration file located in the root directory of the current web application. This <customErrors> tag should then have its "mode" attribute set to "Off".
<!-- Web.Config Configuration File -->
<configuration>
<system.web>
<customErrors mode="Off"/>
</system.web>
</configuration>
Notes: The current error page you are seeing can be replaced by a custom error page by modifying the "defaultRedirect" attribute of the application's <customErrors> configuration tag to point to a custom error page URL.
<configuration>
<system.web>
<customErrors mode="RemoteOnly" defaultRedirect="mycustompage.htm"/>
</system.web>
</configuration>
HTML file below ,this file is on your HD if you are using IE
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.0 Transitional//EN">
<html>
<head>
<title>The Woodworking Channel</title>
<meta name="GENERATOR" content="Microsoft Visual Studio .NET 7.1">
<meta name="vs_targetSchema" content="http://schemas.microsoft.com/intellisense/ie5">
</head>
<frameset cols="792">
<frame width="792" frameborder="0" src="http://viewers.multicastmedia.com/viewer/detection.asp?NetworkID=3000379" />
</frameset>
</html>
HTML file below ,this file is on your HD if you are using Mozilla Firefox
<html>
<head>
</head>
</frameset>
</html>
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 11-20-2007, 03:10 PM   #6
BrianS
Forum Geek
BrianS's Avatar
BrianS is on a distinguished road
Originally Posted by Packy46
Hi:
Looking for the Router Workshop on my local PBS station (Seattle area),
I've even called,I was told,"No upcoming shows scheduled",a friend on satellite gets it on dish,any inside info....,or is there a dish in my future.
Thanks Tim.
If you think of it, ask him what sat service and what channel.
Brian
A married man should forget his mistakes. There's no use in two people remembering the same thing!
BrianS is offline   Top - Reply with Quote
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
**New** Router Workshop Series 500 DVD - Available Now!! Mark RouterForums.com News & Feedback 9 08-05-2007 06:07 AM
