Thread Tools Display Modes
Old 11-23-2007, 09:16 PM   #1
jer760
Forum Fanatic
jer760's Avatar
jer760 is on a distinguished road
Default Drum sanding bits in a router table???
Just doing a small project that would have been simplified with a spindle sander. I don't own one just use a kit on my drill press. It occurred to me that these same bits would fit my router/table setup, any thoughts?
Jer
Miracle Stick! Made of tough, genuine wood!
jer760 is offline   Top - Reply with Quote
Old 11-23-2007, 09:48 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi jer760
The speed will kill the sanding drum it will come apart at 10,000 rpm's
not to say any thing about the cost of adding a TP holder to your router cabinet..
If I recall the max speed they recommend the drums is 650 rpm's
I just recalled I made a spindle sander with a old Hover Vac.cleaner motor along time ago,, I made a box to hold the motor and a pillow block and used a 1/2" drill chuck on the shaft, I guess you could use a 1/2HP motor and do the same thing and a pulley or two to get the speed down and the HP up...
Just a thought
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 11-23-2007, 10:59 PM   #3
jer760
Forum Fanatic
jer760's Avatar
If the max speed for a drum sanding bit is 650 rpm, well, forget the router as it's lowest speed according to spec is 8000 rpm. Hmmmm, was just a thought. Would have been nice to find another way to shape without another footprint in the shop. Oh well.
Jer
Old 11-23-2007, 11:11 PM   #4
BrianS
Forum Geek
BrianS's Avatar
BrianS is on a distinguished road
Many people have used their drill press for just such an operation. I even recall a magazine article that used a fabricated table with a dust collector port underneath it.
Brian
A married man should forget his mistakes. There's no use in two people remembering the same thing!
BrianS is offline   Top - Reply with Quote
Old 11-23-2007, 11:16 PM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
HI jer760
You may want to take a hard look at the url's below
I have the grizzly one, it looked like the best deal to me at 119.oo it's bit bigger than the HF one. (foot print)....plus it will take on the 1/2 " to the 3" drums and with one nut they are off and back on in a flash,ands has bigger top.
Corey got a new one maybe he can post a snapshot of it..it has all the bells and whistles I don't recall what he paid for it......
http://www.harborfreight.com/cpi/ct...temnumber=95088
http://grizzly.com/products/1-3-HP-...le-Sander/G0538
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 11-24-2007, 10:00 AM   #6
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
HI jer760
I just recalled they make a kit to change your drill press into a Oscilating spindle sander,I have not use one one but it just chucks in to the drill press chuck and moves up and down in the device just like the ..spindle sander...
I will try and find the kit and post a link to it..
I didn't find the kit BUT you can buy a bench top drill press for about the same price as the Oscillating sander..and have both in one tool..
http://cgi.ebay.com/Shop-Fox-W1667-B...QQcmdZViewItem
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 11-24-2007, 11:00 AM   #7
kp91
Forum King
kp91's Avatar
First Name: Doug
Just because it fits, don't use it. I've seen 20,000 rpm rated grinding disks fail on a 25,000 rpm grinder. It is amazing how much energy is available should a tool like that fail.
If it isn't sold as a router bit, I personally would not use it in a router. I feel the same way with milling machine tooling, since most of it is designed for milling machines spinning 5000 rpm or less. CNC mills can run into the 10,000-12,000 rpm range, still slower than a lot of routers.
I'm sure a lot of folks have used other tooling with great results, but unless you see the package with a manufacturer's rpm rating on it, I wouldn't use it in a router.
Just my humble opinion, not trying to upset any apple carts....
1 John 1:9
Old 11-24-2007, 11:31 AM   #8
AxlMyk
Supreme Forum King
AxlMyk's Avatar
AxlMyk will become famous soon enoughAxlMyk will become famous soon enough
Shop Fox items
(1) D2677 Drum sander set
(1) D2722 Mandrel (order 3)
(1) D2686 1"x4 1/2" Sanding Sleeve, 120 grit - 3 pack
I found these items at right-tool.com but they do not communicate with you, and I am still waiting for the shipment.
AxlMyk is offline   Top - Reply with Quote
Old 11-24-2007, 03:36 PM   #9
Hamlin
Supreme Forum King
Hamlin's Avatar
First Name: Ken
Without purchasing a oscillating spindle sander, the drill press kit is the best and safest way.
Ken
"A VETERAN"
Old 11-24-2007, 10:48 PM   #10
jer760
Forum Fanatic
jer760's Avatar
Well, it was just a thought but obviously not a good one. 119.00 for a proper setup would be ideal. HF is not open for business in Canada but I'll check and see if Grand Forks has one, we go there fairly often for the unique products available in the USA. I do have a few ideas percolating with regards to making my own but will first see what the manufactured units do and why, safety first. Thanks alot guys.
Jer
need advice for inserting rosseau router plate into bench dog promax cast iron table sf_basilix Table-mounted Routing 7 02-21-2008 07:00 PM
Oak Park Router Table B_Rod Starting Off 27 02-20-2008 07:31 PM
Bosch Router Table Plate Pattern Rhino Starting Off 2 11-24-2007 08:35 PM
handmade router table reds_21 Table-mounted Routing 22 02-13-2006 12:38 AM
Help with buying router table for Hubby's birthday 2jranch Table-mounted Routing 10 10-29-2005 11:39 PM
