| | #1 |
| Registered User New Member | I would like to know the safest way to route edges on irregular shaped pieces using a router table. Is a pin in the table necessary? |
| | #2 |
| Marine Engineer Forum King | A starting pin is necessary, but there alternatives. Anything that is fixed, such as a board clamped tightly to the table a couple of inches away from the bit will work. The main thing is to have some other support on the piece when the piece is fed into the bit. I have had a piece catch and kick back a bit as I brought it into the cutter. You would be impressed how much force a 3/8 roundover bit can generate. Once you are on the bearing, you can move away from the bit safely. Make sure that you are feeding in the correct direction. Going in the wrong direction can pull the work out of your hands, or your hands toward the bit. Also, with any work, try to set up a guard to cover the bit area. Since you aren't using your fence, a fence mounted guard won't help, but if you watch Bob and Rick they use a guard that clamps to the table and hovers above the cutter. Hope this helps,
| | #3 |
| Registered User Supreme Forum King | Good advice from Doug. Be safe! One thing I do if the piece is very curved is to use the pin to start and route in an couple of inches then take the workpiece away, shut the router off then when it has stopped I take out the pin. Power up again and start routing on the part of the work piece that has been routed... away from the corner. Once you are on the work piece you can route without the pin in place. Ed |
| | #4 |
| Marine Engineer Forum King | Oops! In my second paragraph, I meant when you are on the bearing you can move away from the STARTING PIN safely. Sorry if I confused anyone!
| need advice for inserting rosseau router plate into bench dog promax cast iron table | sf_basilix | Table-mounted Routing | 7 | 02-21-2008 07:00 PM |
| Already Problems | neuschu | Introductions | 7 | 01-22-2008 11:32 PM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 07:59 AM |
| First and only (I hope!) Router table | CanuckBeaver | Table-mounted Routing | 11 | 07-25-2007 03:45 PM |
| Problem mounting Dewalt Router to Caftsman Table Saw | apollo2000 | General Routing | 8 | 05-22-2007 07:42 PM |
