Thread Tools Display Modes
Old 12-04-2007, 11:38 AM   #1
wbelknap
New Member
wbelknap is on a distinguished road
Default Face plate and springs removed
I purchased Freud FT3000VCE 3 1/4 HP Router. I wonder if Bob & Ridk make a face plate to fit this unit and use thier table. I also would like instructions on taking out the springs in this router
wbelknap is offline   Top - Reply with Quote
Old 12-04-2007, 11:45 AM   #2
Joe Lyddon
Banned
Supreme Forum King
Joe Lyddon's Avatar
Joe Lyddon is on a distinguished road
http://www.oak-park.com/
Look around... contact, as required...
They are having a great Sale right now... A good time to buy!
Joe Lyddon is offline   Top - Reply with Quote
Old 12-04-2007, 12:12 PM   #3
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi wbelknap
"Freud " Sorry to say they don't as far as I know, but you can get one and drill it out for your Freud..
You may also want to get a setup guide insert ,plus the brass line up pin.
http://us.oak-park.com/catalogue.htm...&product=CR043
As for removing the springs you don't need to and you may not want to because you can do all it from the top side of the table top...
If you don't remove the springs you can stll use the router with the big base on it for your plunge router needs...when you need the big 3 1/4 HP for big jobs..
I do recommend the base plate with the 3 1/8" hole in it, you can make your own ring insert part. or buy one of each.. 1 1/2" and the 3 1/8 hole.
You may also want to take a hard look at the base plate below,you will also need to drill it for your Freud but it's a bit cheaper and it's 3/8" thick.
http://www.harborfreight.com/cpi/cta...emnumber=94331
Router Workshop: Spring Removal
http://www.routerworkshop.com/mark1.html?list=ME05--
Good luck with your quest...
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 12-06-2007, 05:35 PM   #4
wbelknap
New Member
Thanks for the help in dealing with the springs and faceplate of my Freud router
Wbelknap
Old 12-06-2007, 06:23 PM   #5
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
You'er Welcome Wbelknap
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Need Help removing springs from King Canada plinge router chuckwpg Table-mounted Routing 3 04-16-2007 05:58 PM
M12v no springs but doesn't slide easy paulcomi Table-mounted Routing 1 04-05-2007 10:22 PM
Sticky slide without the springs. shrogers Table-mounted Routing 9 10-07-2004 01:12 PM
