Thread Tools Display Modes
Old 01-08-2008, 08:05 AM   #1
bill kay
New Member
bill kay is on a distinguished road
Default Bosch 1617 router base problem
It appears that Bosch may be having a problem with the fixed base shipped with the 1617. Originally I thought it was just me. I have done a little research and am now noticing similar problems being noted on other forums.
I purchased the 1617 and after the second use the router was extremely difficult to remove from the fixed base. The fit was fine in the plunge base. I thought it was just me or the way the fixed base was mounted in the router table. The base appears to have scored and scratched the motor housing.
I called Bosch Customer Support and was handed off to a "Senior Tech". He told me that they weren't aware of any problems with that base but I should drop it off at a "Quick Service Drop Off Point". I did a little over three weeks ago and it still isn't back yet. So much for the promised 5 day turn around.
Bad customer service ... I thought I was buying a quality tool.
Regards,
Bill
bill kay is offline   Top - Reply with Quote
Old 01-08-2008, 02:35 PM   #2
Senior Moderator
Supreme Forum King
Mike has disabled reputation
Bill, you did buy a quality tool. The 1617 is what many "new" products from other manufacturers are designed after. The scoring and scratching you mention is something new to me. I have a pair of 1617's and they have been trouble free for many years. There is nothing in either the housing or motor case that will cause this other than the alignment pin which must be installed in the slot. All manufacturers have problems with quality control and an occasional bad apple slips through. To date Bosch has stood behind their products better than any other manufacturer. I am not surprised at the delay since the 3 week period mentioned includes Christmas and New Years. Give them a chance, they will make things right. If you have any problems contact me by way of a private message and I will help you deal with them. Be sure to save any emails to document the delay.
Mike is online now   Top - Reply with Quote
Old 01-09-2008, 06:56 AM   #3
bill kay
New Member
Hi Mike,
Thanks for the offer to help. I'll keep you posted as we proceed.
I explained to the counter person, at the drop off point, that there were two problems with the base. One was that it was machined improperly, it was an ellipse as well as tapered from small at the top to larger at the bottom.
Problem 2 was the mounting bolt which holds one of the handles protrudes well into the area where the router resides. That probably caused the scoring of the motor housing.
The only part that was sent back for repair/replacement was the fixed base. I got the
impression that I'll just have to live with the galled case.
I spoke with the folks at the drop off point yesterday. They are now telling me that Bosch is doesn't know if it can be repaired and they are not sure of any replacement policy.
Here is an excerpt from a conversation on another forum. It appears that there is a serious problem with a batch of the aluminum bases.
Regards,
Bill
http://www.forums.woodnet.net/ubbthr...b=5&o=&fpart=2
"I told them it was two yrs. old and it is real hard to get it in and out of the plunge base.He said wait a few mins. and left. About 20 mins later he returned my router with a new alum. houseing and a new plunge base. He told me the older models with alum. houseings had been machined wrong and alot of them had to be replaced.I asked if mine had anything to do with a magnisium houseing and he said no. He said mine was an alum. housing to begin with."
Old 01-09-2008, 12:22 PM   #4
Senior Moderator
Supreme Forum King
Bill, I would take some ScotchBrite and polish the motor case and base a bit, then give it a coat of automotive wax. This is a good practice for most brands of routers. Since the damage to the case was apparently done by handle bolts that were too long you can grind off a thread to prevent any future damage. If you follow the path most commonly used you will remove the handles for table mounting the fixed base. Write down the dates you contacted Bosch and any details you remember. Specifics help in problem resolution.
Old 01-09-2008, 12:53 PM   #5
reikimaster
Forum Geek
reikimaster is on a distinguished road
I've got the 1617 with magnesium housing and the bases both have "MAGNESIUM" stamped into them. I have learned that the alignment arrows have to be aligned on the motor housing and the base when you put them together. There's a pressed in pin inside teh base that mates with a groove. If you misalign the 2 parts when installing the motor into the housing, you can actually press that pin out. When that happens, your locking detents don't lock.
Also... at the latch that locks the housing into the base (NOT the detent latch) there is an adjustment for how tight the motor housing will be squeezed by the base when you lock it. If that's a little too lose (real easy to open and close the latch) then it's also real easy to misalign the housing and base as you put them together. The housing lock latch should snap in TIGHT when you lock the housing into the base. When the latch is open there should be definite resistance to rotating the housing within the base. It shouldn't be HARD to move... but it shouldn't be real easy either. If it's a little snug when the latch is open, then you'll have far fewer issues with alignment when you simply use the fine adjustment knob to raise or lower the router in the base.
I'd have to take a look at the handles on mine when I get home to see how far that stud protrudes into the base. I could see where... if it's not screwed into the wooden handle far enough, there would be too much exposed and it would screw too far into the base. In that case I'd probably just add a washer to the stud between the handle and base.
Just stuff I've learned from using my router. Hope some it might be helpful.
reikimaster is offline   Top - Reply with Quote
Bosch 1617 EVSPK switch problem?? Toolfreak Tools and Woodworking 9 04-02-2008 06:34 PM
Colt plunge base bobj3 Jigs and Fixtures 19 04-01-2008 08:54 PM
Bosch 1617 Router jimcrockett General Routing 3 03-24-2008 01:43 PM
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
