Thread Tools Display Modes
Old 01-10-2008, 10:08 AM   #1
earlofroberts
New Member
earlofroberts is on a distinguished road
Default trim router handles
I'm looking for a co. that either makes rubber grip handles for a trim router OR who has a trim router kit with a base with handles.
thanks, earlofroberts
earlofroberts is offline   Top - Reply with Quote
Old 01-10-2008, 10:29 AM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi earlofroberts
I don't know of any company that makes just handles for the trim router but you can make your own, with a new base plate and some wooden dowel stock or just about any thing you want to use for handels....
here's a link to what it can look like..
http://www.routerforums.com/30819-post8.html
http://www.routerforums.com/show-n-t...uter-sign.html
Bike hand grips over wooden dowels would be a nice touch.
I would drill a hole in the dowel (side ways) and one down the center then slip in a 1/4-20 sq. nut and use a Allen flat head cap screw so you can crank it down tight...
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 01-10-2008, 11:04 AM   #3
garyo1954
Dedicated Member
garyo1954's Avatar
garyo1954 is on a distinguished road
I like that BJ. Might experiment with it as well.
Here's another gadget I fixed up for the Harbor Freight laminate trimmer.
The bit is off center of the base so I fit the homemade shoe and ran a 1/4" bit through it.
I bought the bronze bushing from Lowes. That one has a 5/16" o.d. and a 1/4"
i.d.
Once you drill the center hole to 5/16" it fits tight. To be on the safe side, I smudged a little epoxy on the top.
It ain't broke if it can be fixed.
garyo1954 is offline   Top - Reply with Quote
Old 01-10-2008, 11:21 AM   #4
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Gary
That looks good Gary
In this case the bigger the better,,you may want to play with the brass guides for the PC type routers,, 1 3/16 size,,with two drill bits ( 1 3/16" and 1 1/2" ) you can put in a lip to hold them and then you can use all the sizes in your base plate...by using the brass lock ring to hold them in place..
I made one for my Bosch Colt that's 1/4" x 8" x 8" and it works great for many jobs.
http://www.harborfreight.com/cpi/cta...emnumber=95160
[quote=garyo1954]I like that BJ. Might experiment with it as well.
i.d.
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 01-10-2008, 12:11 PM   #5
cbsjoez1935
Forum Fanatic
cbsjoez1935 is on a distinguished road
Hi Earlofroberts,
As stated in the other posts, I don't know of a manufacturer that makes just the handles. I looked at Gary's post and wow does that HF trim router resemble the one from MLCS (Marvel 40). That one comes as a kit with all kinds of attachments including a base with handles on it and a case. It is reasonably priced (for what it does) and comes with free shipping. You might give it a look. I also made a sub-base for mine to accept PC bushings, as Gary did, but with larger square bases (4" & 6").
Joe Z.
JoeZ If you never made a mistake, you never tried anything
cbsjoez1935 is offline   Top - Reply with Quote
Old 01-10-2008, 12:37 PM   #6
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi Joe
Just one user revew
I have both the one from MLCS and two from HF,, the one from HF is a low end router type,, you get a extra set of brushes that should tell you something about the HF router,,, they run great but you can't run them to long at one time,,,they get hot and nail the brushes.. about 3 to 5 mins.max
The one from MLCS is a bit better unit,,not high end but not low end....
It comes with many extras most don't fit well but will do the job..alot of stamped pastic parts...and light sheet metal parts...
All in all I would give the MLCS router 3 stars out of 5 stars.
The HF router I would give it 1 star out of 5 stars...
The Colt 5 stars out of 5 stars
If you want a great trim router I would Recommend the Bosch Colt...
Marvel 40 3-in-1 Router Kit
http://www.mlcswoodworking.com/shops...n1_router.html
1/4'' TRIM ROUTER
http://www.harborfreight.com/cpi/cta...emnumber=44914
I also have the one below
Bosch PR20EVSK Colt Palm Grip 5.7 Amp 1 Horsepower Fixed Base Variable Speed Router with Edge Guide
http://www.amazon.com/gp/product/B00...MQ40W24WFHQNFZ
this one is 112.oo bucks ▼
http://www.amazon.com/Bosch-PR20EVSK.../dp/B000ANQHTA
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 01-10-2008, 11:55 PM   #7
Dr.Zook
Supreme Forum King
Dr.Zook's Avatar
First Name: Dave or "Doc"
Dr.Zook is on a distinguished road
Send a message via Skype™ to Dr.Zook
Welcome to the forums Earl.
Dave
the "Doctor"
Dr.Zook is offline   Top - Reply with Quote
Old 01-15-2008, 08:28 AM   #8
earlofroberts
New Member
the "Doctor",
thanks for the welcome. Reminds me of Dr. Who.
earlofroberts
Old 01-15-2008, 08:41 AM   #9
harrysin
Forum Contributer
Supreme Forum King
harrysin's Avatar
harrysin is on a distinguished road
Me thinks that Earl is very perceptive Dave!
Harry
harrysin is offline   Top - Reply with Quote
Old 01-15-2008, 01:35 PM   #10
Dr.Zook
Supreme Forum King
Dr.Zook's Avatar
Yes, very.
Dave
the "Doctor"
Mixing Bosch 1617 Router fixed base with Craftsman professional router sf_basilix Starting Off 5 01-21-2008 09:54 AM
Motorized Router Lift - Eagle Lake Style johnwnixon Table-mounted Routing 10 09-13-2007 07:59 AM
Full-sized router or palm (trim) router for this job? LBrandt Portable Routing 5 08-06-2006 11:41 PM
