| | #1 |
| Registered User Sr. Member | Is there a maximum size for panels before you have to start using edge glued panels as opposed to just making it out a leftover piece of wood? Length or width... |
| | #2 |
| Registered User Supreme Forum King | I would suggest no more than about 6" wide boards for panel glue ups. My reasoning for this is that the wider boards tend to warp easier. I am by no means an expert on this but, I did stay at a Holiday Inn last night. ![]()
__________________ George If you can't fix it with a hammer, you've got an electrical problem... Last edited by curiousgeorge; 01-29-2008 at 10:50 AM. |
| | #3 | |
| Forum Contributer Supreme Forum King | Hi tpyke The tree rings will tell you all you need to know.. ![]() You don't want them,,,in the center, it works very well if you use 2" to 2 1/2" wide the norm...just flip them over and glue them up, the wider the stock the bigger the cup..this is true for women also it all falls in to place.. mother nature is just that way...Some use the 6" rule but if the tree was only 8" to 10" in dia. well you see what I mean. ![]() ============== Quote:
__________________ Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/W...p_projects.htm Router Tip Archive http://www.routerworkshop.com/router_tip_glossary.html Calculators http://www.routerforums.com/dynamic-calculators/ Last edited by bobj3; 01-29-2008 at 03:01 PM. | |
| | #4 |
| Registered User Forum Fanatic | I don't know of any hard and fast rules but I typically make all panels over ~5" wide from glue-ups. The width of the pieces I use is most times the same as the width of the stiles and rails (usually 2-1/4" for cabinet doors) because I rip all components at the same time.. |
| | #5 |
| Registered User Supreme Forum King | Good tip Charles! Makes sense to me.
__________________ George If you can't fix it with a hammer, you've got an electrical problem... |
| Question on raised panels | kylawyer | Table-mounted Routing | 5 | 03-08-2008 10:44 PM |
| Is there quick fix for slightly loose fitting raised panels? | tpyke | General Routing | 3 | 02-13-2008 07:59 PM |
| Router for raised panels | Jtomwoods | Table-mounted Routing | 3 | 08-21-2006 12:59 PM |
| Question about raised panel router bits | LBrandt | Table-mounted Routing | 2 | 07-08-2006 09:47 AM |
| Raised Panels Quick and Easy | bobj3 | Jigs and Fixtures | 2 | 06-03-2006 12:56 PM |
