Thread Tools Display Modes
Old 02-13-2008, 05:43 PM   #1
tpyke
Sr. Member
tpyke is on a distinguished road
Default Is there quick fix for slightly loose fitting raised panels?
I'm sure I can't be the first to make some raised panels that fit a bit loose...
those riased panel bits with the back cutters seem to take the guess work out of bit heigth adjustment. Which I could have found some when I was buying mine . That's what happens when you're too much in a rush for mail order I guess...
I'm doing a pair of panel doors with 3 panels on each door (6 panels total) and some fit perfect some fit loose, and some I had to give a second pass so they would fit in the slot. Weird...wonder what I'm doing wrong, is it possible to apply TOO MUCH pressure to a piece of wood? Could the OP base plate be warping under the pressure I apply? I'm not leaning on the thing....
I was thinking about maybe putting a bit of clear caulking inside of the slot that accepts the panel. The stuff(Mulco Supra) is kinda like glue but can stretch 350%.
Or should I just leave them as is?
tpyke is offline   Top - Reply with Quote
Old 02-13-2008, 06:36 PM   #2
bobj3
Forum Contributer
Supreme Forum King
bobj3's Avatar
Hi tpyke
"Is there quick fix for slightly loose fitting raised panels?"
They should fit a bit loose ,the panel must float, pickup some foam rubber insulation 1/4" thick and put some in the slots.. 1" long 2 on each side of the panel in the slot...they make balls/strips but you don't need them for a small job...
PodCast videos
RWS on YouTube
Machine Cut ▼
Bob J.
Old 02-13-2008, 07:33 PM   #3
tpyke
Sr. Member
Originally Posted by bobj3
they make balls...
I know....everytime I see them advertised now I can't help but laugh thinking about your post about having them rolling all over the place
Old 02-13-2008, 08:59 PM   #4
Hamlin
Supreme Forum King
Hamlin's Avatar
First Name: Ken
typke, you won't warp the OP plate. Sounds like Bj has given ya the answer needed.
Ken
"A VETERAN"
Question on raised panels kylawyer Table-mounted Routing 5 03-08-2008 11:44 PM
Question about raised panels tpyke General Routing 4 01-29-2008 02:40 PM
Router for raised panels Jtomwoods Table-mounted Routing 3 08-21-2006 01:59 PM
Raised Panels Quick and Easy bobj3 Jigs and Fixtures 2 06-03-2006 01:56 PM
Raised panels CanuckBeaver Tools and Woodworking 3 10-20-2005 01:27 PM
