| | #1 |
| Registered User | I have a PC 6931 plunge base which is extremely difficult to put on and get off the router motor. I've tried to clean off both the motor and the base with a fine abrasive pad, but that doesn't seem to have helped. Any suggestions? |
| | #2 | |
| Forum Contributer Supreme Forum King | HI hes This is LONG SHOT You may have a small crack in the motor mount base,,,this can come about by closing the motor clamp without the motor in place,,,or over clamping the motor down, it's very hard to see so you will need some help, pickup some graphite from the auto parts store or the hardware store ,it comes in a small plastic blow on tube,, put the motor back in place and put some graphite on the out side of the motor mount,,,take your finger and move it around the base, the graphite will show the hair line crack,, if you find one then it's off to the PC service center and with some luck you will get a new one.. =========== Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 02-24-2008 at 08:38 PM. | |
| POrter Cable Router base | aztd | Introductions | 2 | 07-22-2006 01:11 AM |
| anyone pull the springs out of a Porter Cable 890 plunge base? | paulcomi | Tools and Woodworking | 8 | 04-23-2006 06:26 PM |
| Mounting Porter Cable 892 Fixed Base to Router Table | Pack52 | Table-mounted Routing | 4 | 02-14-2006 05:50 PM |
| Porter Cable 6931 Plunge Base | fibertech | Portable Routing | 3 | 08-08-2005 10:34 PM |
| Porter Cable D-Handle Base Question | jayhawk | Portable Routing | 3 | 03-07-2005 05:09 PM |
