| | #1 |
| Registered User Member | Hi guys I'm new to this forum don't even know if I'm posting in the right area, well here go's someone will tell me if I'm not , I bought a job lot from e bay last week and part of the lot there was a couple of routers one being a cheap B/q special and the other a craftsman's with no accessories ,it has turned out to be a good router with little use. I don't know anything about this machine s i live in the united kingdom and i understand they where distributed by Sears in the United States . Its a craftsman router P9209 model 735-2 1/2 horse power 550W 25,000 RPM. can anyone tell me the age of this machine and where i could possible get an owner / instruction manual for it ,and possible accessories for it. I noticed in the side of the router there are two small machine threaded hole just under the adjustment ring could anyone tell me what these are for please . look forwards to your replies thanks for any relies in advance . kind regards MARTIN |
| | #2 |
| Forum Contributer Supreme Forum King | Hi Martin You may want to try Sears for the user manual and the parts you are short.. ![]() BUT Sears jobs out the job for making the routers for them..it can be a PC,Bosch,etc. here's a link to manuals with luck you may find yours listed it will take a bit of digging but maybe it's worth a shot..... http://powertool.manualsonline.com/m...r.html#prdmfgs http://www.theusermanualsite.com/ ============
| | #3 |
| Registered User Member | Hi guys I spent hrs tracing the manuals on the sears websites found who to contact first i had to set up an account with them in sears.ca & sears . canada then sent off a e mail, only to get a reply they don't send parts or manuals to the united kingdom o well back to the drawing board ???? any ideas where else to look i am at the moment looking on e bay.
__________________ you dont have to mad to live here but it does help . _________________________ Master Craftsman Kind regards Martin. |
| | #4 |
| Forum Contributer Supreme Forum King | Hi Martin http://cgi.ebay.com/Manual-for-Sears...2em118Q2el1247 http://cgi.ebay.com/SEARS-CRAFTSMAN-...2em118Q2el1247 http://stores.ebay.com/AMAZEDZ_W0QQf...Z3822797QQtZkm You may want to drop a email to Amazedz he may have the manual you need , I did a quick check on ebay the part number you have may not be the right one.. http://stores.ebay.com/AMAZEDZ =============
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 04-16-2008 at 07:07 PM. |
| | #5 |
| Senior Moderator Supreme Forum King | I'm sure you know that the Craftsman routers only run on 60 Hz. You may find this model was produced by Ryobi since they built a good number of routers for Sears.
| | #6 |
| Registered User Member | Hi thanks bobj3 for the info i'll contact amezdez alater today got to go to town early today . I'll let you know how i get on.
| | #7 |
| Registered User Member | HI Mike Thanks for the info , No i didnt know that, On top of the router it says P9209 THEN router model no 735-2 double insulated 240 volts 50hz ac only 2.3 amps 550 watts 25,000 rpm 1/2 hp distibuted by hagemeyer ltd made inthe usa.
| | #8 |
| Senior Moderator Supreme Forum King | Martin, we all learn something new everyday. This is the first I have heard of a Craftsman router being designed for use outside North America. I hope you will be able to post a photo of this model so others can use it as a reference. Note: You need 10 postings before you can attach photos or URL's the easy way.
| | #9 |
| Registered User Member | Hi guys something i just thought of which I'm not sure about , having never used one of these craftsman's router before, is the diameter of the motor shell which slides into the base unit the same diameter on all craftsman's router right across the range am i right in thinking the motor will fit in say an ordinary base unit, or a plunge router base and not sure what the others bases are called etc. or do they vary in diameter from model to model . thanks in advance .
__________________ you dont have to mad to live here but it does help . _________________________ Master Craftsman Kind regards Martin. Last edited by mjmpropman; 04-17-2008 at 11:53 AM. |
| | #10 | |
| Forum Contributer Supreme Forum King | Hi Mike " Note: You need 10 postings before you can attach photos or URL's the easy way " Must be a error in the spam block ![]() garvan only had 7 posted items but he did post pictures b/4 the 10 post point. see below http://www.routerforums.com/introduc...nation-wa.html http://www.routerforums.com/members/garvan-15152.html http://www.routerforums.com/gallery....0&showthumbs=1 =========== http://www.routerforums.com/71041-post11.html ============== I always thought it was a bit strange,, any one that knows about computers can get right around the spam block with a snapshot, with the URL showing ![]() I think 3 posted min. would be good for pictures, but the URL is good at 10 posted items... I don't think the spammers would stick around for 4 post. How -to- upload pictures to the forum http://www.routerforums.com/howattachment.php ======== see below ========== Quote:
__________________ PodCast videos RWS on YouTube http://www.routerforums.com/86898-post1.html Besure and click on the Up Arrow key ▲ on the Youtube video, you can select other youtube videos on router tables ![]() http://www.woodworkingonline.com/?s=dovetail Machine Cut ▼ http://www.woodworkingonline.com/200...cut-dovetails/ http://www.woodworkingonline.com/woo...podcast-store/ http://www.woodshopdemos.com/menu2.htm Bob J. Last edited by bobj3; 04-17-2008 at 01:53 PM. | |
| Mixing Bosch 1617 Router fixed base with Craftsman professional router | sf_basilix | Starting Off | 5 | 01-21-2008 09:54 AM |
| craftsman router model #26620 | hshumsky | Starting Off | 2 | 01-11-2008 02:58 PM |
| Motorized Router Lift - Eagle Lake Style | johnwnixon | Table-mounted Routing | 10 | 09-13-2007 07:59 AM |
| RouterForums.com and Oak-Park.com - September 2006 Contest!! | Mark | Contests Archive | 72 | 10-01-2006 01:02 PM |
| Help with a Craftsman Router Model 315.275000 | nbat42 | Tools and Woodworking | 6 | 05-27-2005 10:25 AM |
