Thread Tools Display Modes
Old 05-27-2008, 09:10 PM   #1
mftha
Forum Fanatic
mftha's Avatar
mftha is on a distinguished road
Default How far to insert collet adapters?
I have a Makita 3612C router which has a 1/2 in collet and requires adapters for 1/4 in shaft bits. I noticed that the MLCS collet adapters are longer than the Makita collet. Should I insert the collet adapter so that the "top" (the end into which the bit is inserted) is even with the collet top, or should I insert the adapter so the "bottom" is even with the collet bottom?
Tom (NOT Template Tom; I'm nowhere near his league)
One does not know what they are doing until they can make a mistake and correct it.
DO Something, DO ANYTHING to Stop Global Warming
mftha is offline   Top - Reply with Quote
Old 05-27-2008, 09:40 PM   #2
Hamlin
Supreme Forum King
Hamlin's Avatar
First Name: Ken
Hi mftha,
I have 2 of the same routers. I love the Makita's btw. I usually make sure that I put the 1/4" adapter in atleast 3/4 of it's length and then the same for the bit. Sometimes I'm a little deeper with both but, NO LESS than 3/4 of the length of both the collet and the bit shank. I've never had any issues with this method.
Hope this helps.
Ken
"A VETERAN"
Old 05-27-2008, 10:09 PM   #3
mftha
Forum Fanatic
mftha's Avatar
Hi Hamlin,
Thanks. Your answer helps greatly.
Old 05-28-2008, 05:18 PM   #4
Hamlin
Supreme Forum King
Hamlin's Avatar
First Name: Ken
You're very welcome.
Ken
"A VETERAN"
Already Problems neuschu Introductions 7 01-22-2008 11:32 PM
Taste ? (about collet) Benny LaBaw Lobby 11 07-15-2007 09:57 PM
Collet Adapters holdstock Introductions 2 01-15-2007 12:55 PM
Collet insert Bub General Routing 2 01-18-2006 03:34 PM
Router Collet jammed rmq11 General Routing 3 07-05-2005 10:23 AM
