| General Routing Discuss Wanting an edge guide in the Routers forums; I would like to have an edge-guide to attach to the baseplate of my Ryobi RE 180 PL, but ... |
| New Reply | Quick Reply |
| | Thread Tools | Search this Thread | Display Modes |
| | #1 | ||
| Registered User |
I would like to have an edge-guide to attach to the baseplate of my Ryobi RE 180 PL, but have not been able to find one. Does anyone make one for this router? Alternatively I would make one, but am puzzled. The two horizontal holes in the baseplate for an edge guide have a diameter of 0.364", measured with an internal caliper. What size rod is supposed to go in them? I assumed some standard available size plus a little for sliding clearance. Thus for example 0.375" plus a smidgen would make sense. Likewise the spacing between the two holes is bizarre at 3.332". A dimension of 3.25" or 3.375" would be easier. Nor do these dimensions translate into any rational metric measure. Any hints or help will be much appreciated by this puzzled edge-guide novice. xmonday | ||
| | #2 | ||
| Forum Contributer Supreme Forum King |
Hi xmonday Edge guides are easy to make your own, out of hardwood or plastic. The plastic or hardwood will take on threaded holes or you can use a tee nut to lock the rods in place or thumb screws will do the job also. You can also used threaded rod because it's just a bit under size after it's been threaded. For the rods just buy some long 3/8" bolts, cut off the heads and threads and because most bolts now days have rolled threads on the them the rod is under size and should be just right for the holes in the router base... Below you will see a quick and easy one you can make. ========
__________________ Workshop Projects Router Tables plans FREE, plus more http://www.absolutelyfreeplans.com/...op_projects.htm RW Router Tip Archive www.routerworkshop.com/router_tip_glossary.html Last edited by bobj3 : 05-14-2008 at 07:21 PM. | ||
| | #3 | ||
| Registered User New Member |
xmonday, Home Depot has an edge guide for Ryobi routers, I think it will fit all of their routers. hopr this helps John | ||
| Rockler edge guide | Falegname | General Routing | 5 | 12-02-2007 01:54 PM |
| Router edge guide | mwm500 | General Routing | 3 | 11-09-2006 07:30 PM |
| Router Edge Guide for Hitachi Router | cdub101 | Introductions | 2 | 07-05-2006 10:45 PM |
| Rockler Router Edge Guide | reds_21 | Jigs and Fixtures | 1 | 02-06-2005 10:25 PM |
| Edge guide for my PC 890 | paulcomi | Portable Routing | 6 | 10-25-2004 06:21 AM |
All times are GMT -5. The time now is 06:36 AM. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 |
